Modding opinion Design case
Discussion in 'Modding' started by KAMIKAZE-FREAK, 7 Jun 2004.
  1. KAMIKAZE-FREAK
    KAMIKAZE-FREAK New Member
    30 May 2004
    i have a chieftec fulltower dragon
    and i want to mod it
    i want to make my own watercoolingblocks & resevoir
    and i have a huge rad to cool it all
    can i have your opinions and comments?
    This is the rad
    and my sketchup model
    i highlighted some parts , like the pump and the rad so you can recognise them
  2. BlackMan
    BlackMan New Member
    12 Sep 2003
    that rad would only be useful if you had a fan or fans to cover it, that would either need a really big fan or lost of little ones, in other words it would be very loud and probably wont work too well
  3. Rekarp
    Rekarp New Member
    7 Mar 2004
    he could use like 6 120mm fans??
    but he would need a moe powerfull pump
  4. Kingston
    Kingston New Member
    28 Apr 2004
    Can I ask why you would even want a rad that big? It sure doesnt look cool, and performace wise its overkill.
  5. Rekarp
    Rekarp New Member
    7 Mar 2004
    i like it but it looks beat up
  6. Goblin Tinkerer
    Goblin Tinkerer New Member
    24 May 2004
    Hhaha! U could just use a big ars nasty load industrial rolling fan next to it! Put a 50 gallon res on the other side! Next build a keyboard with half foot keys! 11 feet long should be good! Then a monster projection screen and your all set!
    Seriously it might look cool. But its adding 1/3 size to your comp, will be up to 1/2 after you find the fan solution. Definatly will be original though!
  7. Xgamer
    Xgamer New Member
    29 Oct 2003
    It wouldnt be a bad idea to use that rad if you were to put it outside, like this.
  8. KAMIKAZE-FREAK
    30 May 2004
    @Kingston: if it does like i want it to do
    then its a passive cooling
    @reKarp: the otherside is much better
    almost perfect
    @Xgamer: no i want the pc to go to lan-party's
    so it isnt a house mounted cooling
    besides, i live @ my parents house so i just can go killing the walls like that
  9. TMM
    TMM Modder
    12 Jan 2004
    looks like a car intercooler :) even if you did find fans, it wouldn't work... at best performance, as the air needs to travel away after going thru the rad, it'd restrict air flow and make a heap of noise if the rad was bolted to your sidepenel/side of case
  10. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    it wont apssive cool on its own just liek that..;..well it will ever so slightly.
    Stick a bunch of heatsinks to the side of it....ebay are always selling job lots of heatsinks for about a tenner
  11. Rekarp
    Rekarp New Member
    7 Mar 2004
    ya you could try to passive cool or like i said stick a bunch of 120 mm fans on it :D Who would care about the noise. Do it for the sheer cool factor :hip:
    to get it to move you might want to put wheels on it...
  12. robotguy9000
    robotguy9000 New Member
    3 Jun 2004
    :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop:
    wow that thing is huge and ugly... you could paint it but its not worth it because its dented and everything... and yeah you need a bigger pump :duh:
  13. KAMIKAZE-FREAK
    30 May 2004
    i have a pic of the better side but dont know how to make a thumbnail so here tha link <--
  14. Mr.Nonflex
    Mr.Nonflex New Member
    2 Jun 2004
    If i were you, i would look for an other rad, mounting this on your case is no would ruin the looks of your case. And with 6 fans it wouldnt be silent eighter.
    If you still wish to use it, i would make an schroud around it, covering the ugly motha and use some kind of dustfilter to hide it. :hip:
  15. Rekarp
    Rekarp New Member
    7 Mar 2004
    well am urging you to do it. i want to see how this turns out.
    ~rock on :rock:
  16. KAMIKAZE-FREAK
    30 May 2004
    i'm with you
