Notebooks OPINION ON BUDGET LAPTOP
Discussion in 'Hardware' started by pranks7er, 17 Dec 2007.
  1. pranks7er
    pranks7er mange tout
    25 Dec 2002
    i want a laptop basically for bit travelling, ie watch odd dvd etc, browse net etc nothin too demanding
    i seen this and feel it good deal
    can i have opinions or anything else you maybe feel better in the proce range i only want spend 400£
    General
    System Type Notebook
    Built-in Devices Stereo speakers, wireless LAN aerial, Bluetooth aerial
    Embedded Security Fingerprint reader
    Width 36 cm
    Depth 26.7 cm
    Height 3.9 cm
    Weight 2.8 kg
    Colour Silver
    Localisation English / United Kingdom
    Processor
    Processor Intel Pentium Dual Core T2310 / 1.46 GHz
    Multi-Core Technology Dual-Core
    64-bit Computing Yes
    Data Bus Speed 533 MHz
    Features Enhanced SpeedStep technology, Execute Disable Bit capability, Intel 64 Technology
    Chipset Type Mobile Intel PM965 Express
    Cache Memory
    Type L2 Cache
    Installed Size 1 MB
    RAM
    Installed Size 1 GB / 3 GB (max)
    Technology DDR II SDRAM - 667 MHz
    Memory Specification Compliance PC2-5300
    Form Factor SO DIMM 200-pin
    Configuration Features 1 x 1 GB
    Storage Controller
    Type Serial ATA/IDE
    Serial ATA Interface Serial ATA-300
    Storage
    Hard Drive 120 GB - Serial ATA-150 - 5400 rpm
    Optical Storage
    Type DVD-Writer - integrated
    Card Reader
    Type 5 in 1 card reader
    Supported Flash Memory Cards SD Memory Card, Memory Stick, Memory Stick PRO, MultiMediaCard, xD-Picture Card
    Display
    Display Type 15.4" TFT active matrix
    Max Resolution 1280 x 800 ( WXGA )
    Widescreen Display Yes
    Colour support 24-bit (16.7 million colours)
    Features VibrantView, glossy
    Video
    Graphics Processor / Vendor NVIDIA GeForce Go 7300 TurboCache - PCI Express x16
    Video Memory 256 MB
    full spec http://www.laptopsdirect.co.uk/Lenovo_3000_N200_Laptop_TY2BRUK/version-1.asp
  2. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    Looks fine to me, might be worth upgrading the memory though.
  3. pranks7er
    25 Dec 2002
    yea will do
    but the next up is one for 429 it has the better core 2 cpu, no dedicated video tho but not gonna be gaming but then i sacrifice ram for that, is there much diff between core duo and core 2 duo when comes to laptops
  4. Krikkit
    21 Jan 2003
    Core 2 Duo is worth getting over Core Duo if you won't be gaming (seenas the C2D one has no dedicated video card), it's much faster...
    RAM is so cheap atm, there's no reason not to upgrade, so that's not a worry.
  5. pranks7er
    25 Dec 2002
  6. kenco_uk
    28 Nov 2003
    http://www.laptopsdirect.co.uk/Lenovo_3000_N200_0769_TY2BMUK/version-1.asp - Seems like a good one. Tips the scales a little over the £400 mark, but well worth it. Plus, it looks like you can get a deal to up the ram to 2GB (easy to upgrade anyway, as it has 1 x 1GB stick, instead of 2 x 512MB found in most others).
    Even has bluetooth and a webcam built in! Comes with XP Pro, if that makes a difference.
