Modding opinions and suggestions please..
Discussion in 'Modding' started by Seth, 24 Aug 2002.
  1. Seth
    Seth What's a Dremel?
    14 Mar 2002
    what you think people make a plexi cube like the invisable case?
    or make a 2 tier desktop like case , botton tier for drives and psu's and top for mobo?
    for the invisable case
    http://www.bit-tech.net/article/72/
    and for the two tier idea
    http://koreamod.com/ttboard/ttboard...ew&code=42&bname=GALLERY&page=3&SearchBlock=1
    I don't plan to copy them exact, that would be retarded.
    I want to make my own completely but I just want to know what idea you people like better?
    when I am making it I will totally write an article covering the whole thing.
  2. Tribal Dragon
    Tribal Dragon Insomniac modder!
    17 May 2002
    I like the invisible case more.
    I've done one that looks a little like it;)
    but it doesn't matter... you better choose which one you want to base your acrylic case on than listening to people that don't have the same taste as you... you may be disapointed in the end if you don't follow your own taste:D
    well that the way I see it:lol:
  3. Seth
    14 Mar 2002
    I agree, however I really like both.
    I just need some peoples feed back is all.
    thanks.
  4. Tribal Dragon
    17 May 2002
    Mine was based on another plexi case from koreanmods who looks like the invisible case.
    the hard part is to calculate the exact size of the pieces if you make them pre-cut.
    Considering that you like both and don't know which to choose I would go with the invisible case, pretty cool:dude:
    Can't go wrong with Linear :lol: and you can have some guidlines too. if you choose the one from korean mod... well unless you learn korean, you won't know how it was done:D
  5. Seth
    14 Mar 2002
    that is true.. maybe I can speak korean. you never know even though I am swiss heh.
  6. DETN8R
    DETN8R What's a Dremel?
    27 Oct 2001
    I like the 2 teir idea.
  7. MaximaMan2000
    MaximaMan2000 What's a Dremel?
    6 Jun 2002
    If I were to choose, I'd go for the 2 teir. Mostly because of it's looks.
  8. god8y
    god8y What's a Dremel?
    15 Mar 2002
    I would go for some mix of both cases, i like the blue things in the 2 tire case and the smoked plexi, so i suggest build a case like linear (invisible case) but with black smoked plexi and those blue things (atleast thats my opinion).
  9. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    The 2 tier one from KoreaMods looks damn sweeeeet but takes up a lot of desk space.
    Would go for a more convetional tower shape using smoked plexi and of coarse some bloo lighting.
  10. Seth
    14 Mar 2002
    What I think I am going to do is go for the 2 tier idea but a lot smaller then they did.
    I am going to make it just big enough for the motherboard and cathodes then on the bottom everything will be tight together.
    well thank you for your suggestions people. you were all quite helpful.
  11. DETN8R
    27 Oct 2001
    what about air flow and cooling?
  12. Seth
    14 Mar 2002
    on the top I am going to have a few fans or just one in the middle, and then on the front I am going to have 2 blue glowing clear fans on each side and I think the same on the back so it will create a nice flow of air.
    the one on the top will get rid of stagnet air that isn't in the currents and seeing as hot air rises then it is in a good place.
    as for the bottom I am not sure yet I have not put too much thought into the bottom heh.
    the top part has to be big enough for my orb chip cooler anyway so it will not be that short.
