Windows Opinions on Good dvd burning software?
Discussion in 'Software' started by Solidus, 20 Sep 2006.
  1. Solidus
    Solidus Superhuman
    26 Dec 2005
    I wasnt sure where this thread goes, its abit of an opinion question so thought it would suit here best perhaps.
    Im trying to backup some of my dvds since i constantly lend them to friends and i rarely ever see them again (friends hey...grr)
    Nero6.0 doesnt seem to cut it, it keeps getting a read error/burn error when reading dvds now and then and from what im told, theres better stuff out there,
    What do you guys use or think is best to backup your movies?
  2. Guest-16
    Guest-16 Guest
    How about a better writer, better cable or better media?
    Nero 7?
    Burn at lower speeds?
  3. Ryszvaldo
    Ryszvaldo Banned
    3 Jan 2005
    Lower speeds using Nero 6 on good media I find the best, I have had issues with the MP3 encoding and burning in Nero 7 so I don't use that anymore. DVD Santa is pretty good as well.
  4. Solidus
    Solidus Superhuman
    26 Dec 2005
    Im using NEC writers which i hear are meant ot be good?, i guess il give the lower speeds a try. fingers crossed. :)
  5. specofdust
    specofdust Banned
    26 Feb 2005
    Nero is the only burning software worth bothering about. V7.0 is the one to go for imo, but V6 is great too. If you have problems, I'd suggest that they aren't nero's fault.
  6. woof82
    woof82 What's a Dremel?
    18 Jul 2005
    I didn't get any software with my dvd drive because I got it second hand. I downloaded a few things but either they were rubbish or the trial periods ran out, either way, I'm using a VERY simple program called "Burnright! CD & DVD" that actually works pretty well, so yeah, give it a whirl.
  7. Atomic
    Atomic Gerwaff
    6 May 2002
  8. SeT
    SeT What's a Dremel?
    7 Oct 2003
    as far as backups, I've had good luck with dvd decrypter. as far as burning, it does have a burn option and does just fine burning the img files it creates.
  9. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    If you're getting read errors, it's probably copy protection (ARccOS) on the original disc.
    There is a plugin for DVD Decrypter called PSL2 (links DVD Decrypter with PCGEdit) which automatically reads and "repairs" copy protected discs so that you can make your backup copies. More info here
