Scratch Build – In Progress OPTERON PRIME - Supermicro 4P folding mayham - folding numbers
Discussion in 'Project Logs' started by Hukkel, 25 Jul 2013.
  1. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Right. Where was I?
    Oh right. I had fitted the modules and the waterblocks and then the light went dim outside :D
    Well I took some photos to show you guys.
    I will toss in another update right after, because I picked up something this morning and I just can't wait to show you guys :shaky:
    btw the mobo is getting VERY heavy now. I hope this many waterblocks on there won't cause any trouble.
  2. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    Mmmmmmm. water blocks...:baby:
  3. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Sexy hardware. Erm, why are those photos taken 20+ days ago?
  4. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    plumbing won't be easy here :)
  5. Hukkel
    20 Dec 2012
    :hehe:
    Because I usually make a bit of a backlog so I can keep a constant flow of updates for the people that enjoy weekly updates. And when I have to wait for parts a few weeks my log doesn't die for weeks on end making people think it won't be finished.
    You are correct, but I'd like to think of it as a....challenge :hehe: :D
  6. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Ah, I see. So,when we will see MBO block on MBO with other sweet hardware? :)
  7. Hanoken
    Hanoken O.O
    12 Jul 2012
    I stopped looking in the logs for a month so that I can let all the logs I'm following to get some progress... and lo and behold I saw a new build by hukkel... uh sir when did you start such a crazy build?? Guess ill have to put a tab on this one and grats on your sponsorships :D
  8. branndailor
    branndailor What's a Dremel?
    28 Feb 2012
    since watercooling loops reaches a overall temperature and stabalizes it, it doesnt really matter where the rads are in the loop.. so he could just do this [​IMG]
    and having the tubes enter and leave from the top of the board and going around in a way the the tubes are hidden.
  9. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    This project clearly doesn't have enough waterblocks.
  10. jackjack
    jackjack What's a Dremel?
    24 Sep 2009
    Sick build, love it!
  11. ColdzeroTeam
    ColdzeroTeam What's a Dremel?
    9 Dec 2010
    i'd split that wc into two loops. one for each 2 cpu and 2 ram blocks.
  12. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    +1
    Although its not an OC loop so the temps will be very low anyway with minimal thermal saturation.
    I dont know enough about Opteron thermal dynamics to say much more,one loop is certainly do-able IMHO
  13. Hukkel
    20 Dec 2012
    I have actually done a few things but I have been away on holiday and I am also finishing my other project. I just ordered plexi panels and a lot of fillports and can go from there again. Due to a communication error I received the wrong radiators. EKWB were kind enough to replace these for the correct ones and they are also upgrading me to their newest black HD tubing fittings. So a small bit of delay. But in the end it will help the build.
    Thank you very much my good sir.
    I started on this quite recently. You're still in time to follow the maddness ;)
    The tubes will indeed be routing over the top. Correct. But I will be using 2 separate loops.
    :D :thumb:
    Thanks JJ!
    Thanks for your input Ricardo.
    So you would separate in a left and right loop (left and right side of the mobo)?
    I was thinking cpus and ram separately because the ram modules are much higher placed. So I would have two separate loops in different depths of the view.
    True. One loop is doable and has been done before. But the eye wants some candy as well :)
    Plus I want to have some overhead for when possible AMD cards are added to the system as well.
  14. dream1
    dream1 What's a Dremel?
    26 Feb 2011
    This is monsta vata kuula :)
  15. Cheapskate
    13 May 2007
    The southbridge-ery looks left out. I say go with the spaghetti look- Run everything parallel!! A little red in the coolant, and it'll look like the inside of a tauntaun.
  16. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    I was going to say that. All that water only for there to be two horrid whirry little fans left :(
    Hopefully this gets the GPU backing it deserves and they'll be buried under four Titans (or something). :)
  17. The_Crapman
    5 Dec 2011
    :thumb:
  18. B NEGATIVE
    8 Aug 2011
    You Sir are composed mainly of Win.
    Forget the parallel nonsense,Roll with the intestines look for awesomesauce
  19. AlienwareAndy
    7 Dec 2009
    woot woot
  20. Colossous
    Colossous Minimodder
    28 May 2007
    That really is a lot of awesome kit !
