Hi, I'm wanting to connect 2 devices to 1 home cinema system through optical cables and have been looking for a splitter of some kind to do this. the only problem is that I can only find a splitter from 1 device into 2, the opposite of what I need! Has anyone else seen what I need? Or is it even possible?
I doubt you'll get anything to connect 2 devices to the same input. How would the system work out which it was meant to be using?
You need to be searching for an Optical Switch mate E.g http://www.amazon.co.uk/HQ-Optical-TOSlink-Port-Switch/dp/B000QRI2EI
That Switch looks like the thing I need! Only other ones I have seen have been to swtich the output Thanks guys
