Education Optimise company wide network. What's the battle plan?
Discussion in 'General' started by dragontail, 26 Mar 2011.
  1. dragontail
    dragontail 5bet Bluffer
    9 Jun 2005
    I've been asked to lead a company wide internal networking review.
    * Software based company with 5 or 6 sites, 30-40 staff, many computers.
    * It's a bit messy at the minute, loads of VPNs going everywhere (hence the review).
    * The time scale is months.
    * Things to look at include accessibility, security, growth potential, performance, resilience, etc.
    * Technical director has offered guidance.
    At this point you're thinking: cheeky question son! Go do some research you lazy punk. Haha I agree - but this is difficult - I'm a graduate 6 months in and haven't done anything like this. Don't get me wrong, this is challenging but in a good way - all I'm looking for is advice. Anything you can think of really. Fire away.
    Fwiw, my first step is to get a Test Plan. Currently deploying googlefu.
  2. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    I have next to no experience networking myself (think bog-standard 200 square meter villa).
    What I would do is draw up a schematic of how everything is connected at the moment, then consult your list of objectives with the restructuring, and then start moving pieces about :)
    dragontail likes this.
  3. dragontail
    9 Jun 2005
    Agreed. How do you do a review if you don't know what it looks like right?
    Ah, things like this makes me wonder how rubbish my own home network is :lol:
  4. Fruitloaf
    Fruitloaf Tinkerer
    5 Jun 2002
    Apart from finding out what you have now you haven't mentioned what you are hoping to achieve and what sort of budget you're looking at? With 5 or 6 sites you haven't really got many people per site and if they're geographically dispersed they could be a pain to support.
    It sounds like this could be a perfect scenario to deploy something like Google Apps and keep all your stuff in the cloud to reduce your support and backup burden while giving you some good collaboration software. Alternatively a centrally hosted email solution plus something like jungle disk is an alternative that might work for you.
    One place you might want to think about heading for some advice is the Spiceworks community (https://community.spiceworks.com/) which is excellent for this sort of thing.
  5. bemused
    bemused What's a Dremel?
    9 Jan 2011
    Looks like you need some Cisco ISRs and learn to take advantage of networking companies 'pre sales' cycles.
  6. dragontail
    9 Jun 2005
    These are great suggestions, thanks chaps. I'm looking into all your suggestions, keep them coming. Anything - for example have you used a good networking tool in the past? Seen something done bad that should be avoided?
    And of course much deserved +rep for the help!
  7. Fruitloaf
    Fruitloaf Tinkerer
    5 Jun 2002
    The Register has recently had a few articles on network diagramming tools that you might find useful.
  8. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    Not meaning to be blunt, but your average network consultant would charge a grand a day to fix this for your company, the cheeky sods are making you do the leg work for nuffin extra, make sure you get the best out of it - maybe tell them you need a N+ or CCENT bootcamp so you can learn the technology involved to get the right answers ...
    I'd recommend you get a Cisco ASA5510, on a static IP address, and connect everything into that. If you need resilience you can buy two and put them into stateful failover mode, but you'll need two public IP addresses for it, and then you have to ask how your ISP resilience will work, because the static IP won't necessarily failover between the two, unless you get resilience via your ISP.
    They'll be around £1700 each, and would serve as enforcement point for internal connectivity, as well as providing both L2L and VPN Client access to internal and external individuals.
    You'd then apply an ACL on each VPN to only allow them to access certain resources on your local network.
  9. dragontail
    9 Jun 2005
    Ah thanks Zoon. It's a bit of a learning curve I admit. The MD is looking at potential CCNA courses which should help massively. I'm always keen to do a bit of proactive research though.
  10. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    windows 7 ultimate and windows server 2008r2 with branch cache et al set up, should mean no more vpns here there and everywhere
    branch cache
