Electronics Opto-isolators OK with 70v AC?
Discussion in 'Modding' started by Oclocker, 21 Jan 2003.
  1. Oclocker
    Oclocker What's a Dremel?
    21 Jun 2001
    OK have a sheet of EL sheet 6" * 4" with inverter sheet can be trimmed to different sizes - so I wanna do a lighted badge as a HD activity meter and a lighted panel behind some blue tinted acrylic and maybe something else but want to control each section independently? If an opto isolator isn't suitable for 70v and a few milliamps - is there an easy way to do it?
  2. Cheese
    Cheese Doc
    6 Oct 2001
    I'm no optoisolator buff but I doubt they can take 70V ac.
    I'd put the isolation before the invertor, not after it - and maybe use an optisolator followed by a transistor to isolate the hdd header from the invertor.
    Rob.
  3. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    Yeah you can, but you need a TRIAC optoisolator.
  4. Oclocker
    21 Jun 2001
    But I want to switch different bits of the EL sheet on/off at different times?
  5. Oclocker
    21 Jun 2001
    Thankyou I shall investigate them.. :)
  6. linear
    linear Minimodder
    5 Oct 2001
    I've previously given some consideration to the problem you've stated. I was cooking up a VU meter made of EL sheet, or something equally fanciful.
    The inverter (for most designs I've looked at) needs to see some load to oscillate. I don't think you can just switch off the load without hosing the inverter (but again, designs to do that may exist--The one I looked at from ELCustomshop may be suitable for that kind of stunt--in fact, I bet it is since it's seemingly based on step-up rather than flyback).
    But I would maybe explore some way of switching stepped-down mains AC instead of using an inverter. In US, we have EL nightlights where the lamp just connects across the mains, no circuitry whatsoever. You'll have a little bit of a stepdown to do,and the frequency is not ideal but its workable, but then the triac optos like SteveyG mentions would be quite suitable (plus affordable).
