Windows or maybe Hardware/Network card? OTHER PCI BRIDGE DEVICE
Discussion in 'Tech Support' started by captisabella, 29 Apr 2012.
  1. captisabella
    captisabella What's a Dremel?
    29 Apr 2012
    So, I updated my drivers on my desktop and now I can't connect to the internet on it! YAAAAAY!
    It wants me to change the driver for "Other PCI Bridge Device" to the proper one, but I don't know which one I need. YAAAAAAY!!!
    Please help. :(
    :wallbash:
  2. happysack
    happysack goodateverthinger
    19 Dec 2009
    Hi there,
    You could use system restore or 'roll back drivers' ?
    alternatively go on manufactors website for you Mobo and all your hardware and install a driver for each one by one.
    also check windows update (manually)
    and intel driver update utility.
    you will be able to get it somewhere.
    To make it quicker, goto properties and get the HARDWARE ID of the device you cant get a driver for and put it in google to get some idea of what the driver needed is.
    Cheers,
  3. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    in device manager, get the properties up for the device that has no drivers, then details, select hardware ids and look for pci/ven_ blah blah, then goto PCI Vendor and Device Lists and search with the info you have.
