Modding Orac 3 , question
Discussion in 'Modding' started by Ace_Ventuora, 9 Apr 2004.
  1. Ace_Ventuora
    Ace_Ventuora What's a Dremel?
    9 Apr 2004
    How did he get the metal so shiny? I did not find the anser enywere.... :sigh:
    (Exuse me for my english, I'm norwegian :hip: )
  2. orb
    orb satisfying.
    23 Dec 2003
    hes got the oh so nice chrome platings.
  3. Ace_Ventuora
    9 Apr 2004
    What does that mean? :worried:
  4. orb
    orb satisfying.
    23 Dec 2003
    He pays to get them chrome plated, and they come out so shiny like that, its expensinve i think
  5. Twitch
    Twitch What's a Dremel?
    13 Mar 2004
    Kind of like how many people do with there cars, just for looks.
  6. x3r0
    x3r0 What's a Dremel?
    29 Oct 2003
    The first thing that all of you are forgetting is that those boxes are PLASTIC, not metal.
    And you cant chrome plastic
    There are other methods that provide a similar result to chroming, the quickest way to find out would be to find the bit in the orac thread that tells you how he did it.
  7. Atomic
    Atomic Gerwaff
    6 May 2002
    Yes you can chrome plastic, as seen in those pictures :p
    You just have to paint it in a conductive metal paint first, this is what was done with orac.
    You can get a simular effect by sanding and polishing metal, this is the cheaper method.
  8. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    Welcome to the boards! (wee! another Norwegian! :) )
    if i remember correctly the plastic boxes are coated with a cunductive paint first that the crome can stick to... (this is a chemical/electrical process i think)
    (BTW: it's spelled Ace ventura :p )
  9. ChegsJAR
    ChegsJAR What's a Dremel?
    7 Sep 2003
    Atomic you beat me too it :D
    I have some chrome spray paint I'm going to use on my other case to see how it looks. My Mum used the gold version over christmas (no on a pc for some christmas type things or somethign) and I used some of it on a test piece of plastic and it looks good. Although there was bubbling it was extremely cold and I hadn't cleaned the plastic :duh:
  10. Ace_Ventuora
    9 Apr 2004
    I know. I just have that name everywhere...
    And thanks for the quick ansers :thumb:
