Modding Orange Cathode
Discussion in 'Modding' started by BioSniper, 26 Sep 2003.
  1. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    Can I get orange cathodes anywhere at all?
    the only once I can find are the normal, yellow, white, blue, green, red, purple, UV but for my project I need an Orange cathode. any ideas or do they just not make them?
  2. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    if you can't find one, just buy a white one and buy some orange (red and yellow mixed could do) bulb paint...
  3. pranks7er
    pranks7er mange tout
    25 Dec 2002
    orange cathode that would look nice let us know if you find one :D
  4. Dad
    Dad You talkin to me?
    15 Apr 2003
    What about a red tube with yellow celophane?
  5. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    Wouldn't a white tube with orange cellophane block less light?
    (If you want orange case lighting, you could of course just buy a lot of bright orange LEDs. You get quite many for the price of one cathode. You could even put them in a plastic tube to make them as easy to handle as cathodes.)
  6. Dad
    15 Apr 2003
    :wallbash: Don't you hate it when you overthink things?
  7. TITAN
    TITAN What's a Dremel?
    26 Aug 2003
    I've got an orange neon built in inverter, molexed, plus a switch.
    I could sell it to ya on the cheap.
    Pics up in a minute...
    Looks much more orange in person.
    $5.00 + shipping from US zip 52804 sounds fair.
  8. BioSniper
    5 Feb 2002
    Thanks for the Offer titan but a Neon is a little large for what I need to do. Cheers for the thought/ideas guys. I'll have to consider which one is the best and use it.
    thanks!
  9. death_star
    death_star What's a Dremel?
    14 Jul 2003
  10. BioSniper
    5 Feb 2002
    Thanks for the google Death_Star but I already tried it and came up with the same.. UV Reactive Fans with Cathodes pre-attached. I have some bright orange LED's but sadly I dont think they will give the effect I want, the light would be too focused.
    Has anoyone had any experiance with using gels and any idea where to get them in the UK ?
