Networks orange light and no green light on my A7N8X Deluxe
Discussion in 'Hardware' started by noesis, 15 Jul 2004.
  1. noesis
    noesis What's a Dremel?
    3 Mar 2004
    Hi,
    I can't connect to one of the three PCs on my network. The crossover cable is fine - I've tested it. When I connect the problem PC to either of the LAN ports on my A7N8X the green light doesn't come on - instead only an orange light is illuminated. The network wizard gets stuck when trying set up the network.
    Can anyone explain the meaning of that orange light?
    I have three PCs linked with two crossover cables. My central PC has two ports so i'm planning to bridge the connecting between the two adapters for a 3 PC network. That should work right?
    Thanks
  2. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    iirc green = link and orange = activity, hence the orange only coming on, must be some kind of error, with a dodgy nic on the other pc, especially if the cable works...might need to get a new one tbh, but tis only a couple of bucks!
    in theory what you want to do with your network should work fine, i have only had minor issues with running crossover cable networks, but aslong as the cables are definetly working it should be easy...
  3. noesis
    3 Mar 2004
    The network cards on all the PCs are fine. I have managed to network every computer to just one other computer. The network cables have all worked in other setups aswell. The problem is I can't network one particular pair. I always get the orange light and no green light. Do you know if there is any documentation on the mainboard's network adapters? I can't find any :wallbash:
  4. coorz
    coorz Miffed
    25 Apr 2003
    Check the connection mode in the ASUS NIC's properties. Whether it is set to auto or half/full duplex.
  5. SJH
    SJH Minimodder
    24 Dec 2003
    Installed the drivers from the CD that came with the motherboard?
  6. noesis
    3 Mar 2004
    Thanks for the help people. In the end I just installed another network card that I had spare. Everything worked straight off. Must have been some sort of strange compatibility issue.
    cheers
