Scratch Build – In Progress Organic II - home linux server
Discussion in 'Project Logs' started by awadon, 13 Jun 2011.
Witch shape do you prefere:
Poll closed 23 Sep 2011.
  1. With the arm and "bud"
    7 vote(s)
    31.8%
  2. without it
    15 vote(s)
    68.2%
  1. awadon
    awadon What's a Dremel?
    23 Jan 2010
    The next stage of modelling. Holes will serve as ventilation. Unfortunately dremel failure slows me a bit. It is hard to shape them with another tool.
  2. GF4rce
    GF4rce What's a Dremel?
    14 Nov 2010
    Very nice design, keep work!
  3. awadon
    23 Jan 2010
    I'am still shaping the form.
    Here at the very top there will be warm air outlet. Something like a chimney.
    I have a concept how to cover all those holes. (There will be more of them). But any suggestions will be greatly appreciated:)
  4. awadon
    23 Jan 2010
    A few photos. As you can see, there's little progress. Mostly, because glueing wood takes a lot of time.
  5. awadon
    23 Jan 2010
    Small update. Unfortunately photos taken with a lamp :(
  6. awadon
    23 Jan 2010
    Grinding, grinding and grinding. Still a lot of work ahead of me.
  7. Karrek
    Karrek Minimodder
    7 Jun 2011
    I love this look! very creative.
    For the holes, you coud attach screening (from a door or window screen) to the inside of the structure. Maybe attach with a staple gun? I wouldn't put anything on the outside - I think that it looks good with the holes. Another idea might be to use flame to darken the wood inside the holes, fading from the natural outside to the dark interior...
  8. Blooddrunken
    Blooddrunken In Flames we Trust
    8 Apr 2010
    wow - it's coming out nicely - I'm looking forward for more. :thumb:
  9. Fuganater
    Fuganater What's a Dremel?
    6 Jul 2011
    Very cool. You could probably bend some modders mesh for the holes.
  10. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Maan, the pattern in the wood looks so awsome! Great work so far!
  11. awadon
    23 Jan 2010
    Yes. I was thinking about something similar. For now there are two ideas:
    1. Using brass.
    2. Using black plexi.
    But I'm still thinking.
    Too easy. And not in my style :)
    I know. I love the look of almost any fruit tree wood :)
    Yesterday I've glued back plate to the case.
  12. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Wooooooooow that looks awesome my friend!!! Really really nice job, I would like to have something similar in my living room!! Mod on buddy cant wait to see more of this! :)
  13. awadon
    23 Jan 2010
    Looking at your mod I think you will :) I was inspired by something you should know very well - olive tree :)
  14. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    Thats a funky wood build, I like it :D
  15. awadon
    23 Jan 2010
    Small progress of the work. I am more and more delighted with the new grinder.
    And some new pictures
  16. ColdzeroTeam
    ColdzeroTeam What's a Dremel?
    9 Dec 2010
    wow... great work you've done here...
    love the chuncks of real wood. also love the fact that there are no flat surfaces.
  17. awadon
    23 Jan 2010
    Thx ! :)
    Practically, I managed to give a proper shape to the case. Still a lot to sand, but roughly it is already in the target shape.
    In the meantime, I have to finally design how to cover the "holes". At the moment I came up with two variants.
    1st Using brass. But I do not really like this idea.
    2nd Using a black Plexiglas. Here is a green insert. But ultimately I consider only the black.
    Well, now I would ask for advice. How to bend plexi to get similar shape as on the photo ??
  18. barry99705
    barry99705 sudo rm -Rf /
    20 Apr 2008
    Heat it up. Hard part will be heating it evenly, needs a pretty big oven, or you could do it in smaller parts, say a couple inches bigger than the holes, then lay it over the holes once it's hot and massage it to shape. You won't have much time, probably less than a minute.
  19. Mechh69
    Mechh69 I think we can make that fit
    16 Sep 2009
    You could probably lay the plexi over the holes and use a industrial heat gun like ones for plastic welding something like this but maybe not as expensive at least you can get the idea
  20. -Jv-
    -Jv- What's a Dremel?
    29 Mar 2011
    I've had a go at those (Well, not that model; One from Makita) and they will melt anything with ease ! I love it for heatwrapping or even soldering !
