Hey guys! This is my first message (and question here) My question is what's the easiest way to take off the case original painting? Im trying to do this using a sandpaper but I need something easier. I own a Thermaltake Xaser III Blue case. thanks a lot!
Welcome to the boards! I've always found sandpaper is usually the easiest. Try paint stripper, may be faster but I've never had much luck with it. (personally I think you should keep it blue)
tks Since I don't have any tool to use the sandpaper, what sandpaper kind do you recommend? I own a Sandpaper for metals, its "thickness" is 60 but I'll take years to finish the paint removel... unless i'm doing something wrong
i used metal paint stripper a sander and sand paper then used wet and dry visit my project link is in sig !
