Windows OS fail?
Discussion in 'Software' started by M3G4, 16 Nov 2003.
  1. M3G4
    M3G4 talkie walkie
    13 Dec 2001
    Every few days or weeks, Windows just freaks out. Sometimes it comes up with an error "Windows has just recovered from a serious error", the screen being in 16 colour etc, keyboard and mouse not working. I reboot like it tells me to, and then windows claims one of the directories (\system32\something) is missing. I can't get into windows.
    Other time, I listen to an MP3 or something, anything memory intensive such as sound editing/recording, and the system freezes, the sound getting stuck. Yesterday, the MP3 went all crackly, the monitor lost signal and I couldn't use the PC. I restarted it, and it complained while in windows that system files were being overwritten with unrecognized versions and I should insert the OS disc. So I did. Then I restarted, and then I couldn't login because of license errors or something. I rebooted again, and then the PC rebooted itself whenever it got to the login screen.
    This happens quite alot. I've been told it could be my RAM chips are dodgy, but I ran Memtest for roughly 45 mins/1hr and no errors were found.
    What could it be?
  2. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    hard drive
  3. Hex
    Hex Paul?! Super Moderator
    11 Jan 2002
    Have you had a look in the Event Log? It might have some clues in there. Does it let you back in eventually without you having to reinstall or anything?
  4. RTT
    RTT #parp
    12 Mar 2001
    M first instinct too. Especially the crackly mp3 thing...
  5. M3G4
    M3G4 talkie walkie
    13 Dec 2001
    Hmm. It could be. Once, it was playing a 3GB video that I had made, and stuttered and stopped. Restarted the machine and the drive ID was gobbledegook. Gave it it's own IDE channel and it's been fine ever since.
    I've not had any problems with the drive apart from that. How can I tell if it's the HDD? Wouldn't RAM cause problems like that too?
    Hex: No. I have to format the thing :(
  6. tk421
    tk421 Idiot.
    15 Jan 2002
    could also be a dodgy power supply ... if stuff like ram and hdd arent getting clean power, it will appear that said components are failing.
    i always troubleshoot in this order (just from personal experience)
    1: psu
    2: ram
    3: ide cables
    4: hdd (if practical)
    5: cards
    6: mobo (again, if practical)
    7: software
    8: OS
    i like to work from simple > complex ... cause i really hate formatting and resetting a pc, just to discover that a ram stick was half out or a nic went tits-up.
  7. TITAN
    TITAN What's a Dremel?
    26 Aug 2003
    Switch around #3 and #1, and that's my troubleshooting order as well.
    Just for gits and shiggles, when's the last time you scandisk/defragged M3G4?
  8. M3G4
    M3G4 talkie walkie
    13 Dec 2001
    Quite a while back, whenever I ran diskeeper, after a while, explorer would crash and bring diskeeper with it
  9. M3G4
    M3G4 talkie walkie
    13 Dec 2001
    Happenned twice again this week.
    Just used ASR to sort it, but it's very frustrating. Was watching a streaming video, sound crackled, monitor lost signal.
    I reset the machine. Managed to log in this time. Came back to machine after lunch to see error dialog "Windows has just recovered from a critical error". Reset the machine because it wouldn't respond
    "Windows could not start because the following file is missing or corrupt:
    \WINDOWS\SYSTEM32\CONFIG\SYSTEM"
  10. Carbon
    Carbon Banned
    8 Jan 2003
    hmmm, this seems helpfull to me too, i got errors with mine too...im thinking PSU now..i might test it later
  11. Astrum
    Astrum Dare to dream.
    8 Mar 2002
    The PSU is the culprit more often then you would think. I'de say more but I feel like I'm going to die right now... Man I don't feel good... Uggg...
  12. M3G4
    M3G4 talkie walkie
    13 Dec 2001
    Really?
    Mine's a QTEC 550W PSU... what's yours?
    I do sometimes hear the intake fans speed slow down, speed up etc. Sounds weird...
  13. Carbon
    Carbon Banned
    8 Jan 2003
    mines a hyper power 420W psu... im just gona try another psu in my system and if it works then ill just replace the psu, if not i dunno
  14. M3G4
    M3G4 talkie walkie
    13 Dec 2001
    Maybe I should try the 300W PSU in my mums PC :idea:
  15. M3G4
    M3G4 talkie walkie
    13 Dec 2001
    I found another problem
    I came back home from some celebration thing, and I had left the PC on. When I turned the monitor on, it was at lowest resolution, lowest colour depth etc, and there was an error box telling me the PC had recovered from a serious failiure of somesort
    Usually it would have hanged here, and then started the "reboot at login screen" thing, but it hasn't. Instead, it works properly, but the system stutters alot - while logging on the mouse stutters all the time and in some cases freezes in its place until the desktop is displayed. MP3's stutter occasionally etc. It's never done this before, and according to windows there is always around 256+ MB of RAM free. But the effects are similar to those when there's hardly any RAM available.
    I've been talking to my friend and he reckon's its faulty RAM.
  16. Thumperup
    Thumperup What's a Dremel?
    21 Nov 2003
    A good clean Format and reinstall is in order I think :D
    but thats just me I like to clean my system completely every couple months
  17. modernmike
    modernmike What's a Dremel?
    8 Jun 2002
    i had a problem with explorer keep crashing and other programs would go into this wierd font anyway, in the end it was coz i droped my 80gig drive on the floor i think that what caused the problem so now i limted down to just 30gigs. and everything works fine :D
  18. Hex
    11 Jan 2002
    M3G4, seeing as it hasn't completely died this time have you had a look in the Event Log? It may give you a clue to what the "serious error" was that it recovered from?
    Thumperup: M3G4'a been reformatting and installing all along. There appears to be some hardware issue that makes this happen regularly.
    Anything you have spares of, try 'em. If you have a spare HDD try that for a bit. See what happens. Same with RAM and PSU.
  19. M3G4
    M3G4 talkie walkie
    13 Dec 2001
    It packed up again today, had to format :(
    I didn't get a chance to check the event log DAMNIT!!!
    I'm gonna get new RAM and HDD anyway, so I'll have a fiddle when I get them.
  20. Hex
    11 Jan 2002
