Other OS for torrentbox/seedbox?
Discussion in 'Software' started by Sir_Bill, 11 Feb 2009.
  1. Sir_Bill
    Sir_Bill What's a Dremel?
    11 Feb 2009
    Hey all!
    New here in forums although i was reading Bit-Tech for over 1.5 years!
    I have a question for the gurus out there.
    I have the following:
    The wd250GB will change with a wd10eads.
    The question is:
    What os should i use for just dl/ul stuff.
    Nothing else.
    What i do at the moment in my main pc.
    I have a folder where i put the torrents -->utorrent picks them---->downloads them--->transfers them to my temporary fileserver---->continues seeding.
    That's what i want the torrentbox do.Nothing else!
    Any suggestions?
    I am noob concerning linux.
    I remeber having istalled once but it consumed 20gb of disc space,so too much waste stuff!
    Thanks a lot in advance!
    Aaaaaaaaand WELCOME ME!:rock:
  2. Glider
    Glider /dev/null
    2 Aug 2005
    Debian, 350MB and does just what you want it to do...
  3. Sir_Bill
    11 Feb 2009
    Thanks for your reply!
    I downloaded and installed debian and it ended up consuming 20gbs.
    It had open office and 20 games!
    I might have downloaded the wrong version or whatever.
    Linux noob!
  4. lcdguy
    lcdguy Minimodder
    25 May 2004
    Glider was probably talking about a nofrills command line install of debian. You probably installed the full blown install with all the everything turned on and a gui.
  5. Glider
    Glider /dev/null
    2 Aug 2005
    Yeah, the netinstall takes up a LOT less :D
  6. Sir_Bill
    11 Feb 2009
    The iso i downloaded was 180mb!It was the netist iso.
    I don't knwo why it turned out to be 20gb of installation!
    Where do you found the 350mb installed?
    Could you please point to me a link and what to download?
    I don't want to have 20gb of crap (games/openoffice etc)
    OS + torrent!
  7. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    At the end of the install sequence when it asks you to select your machines usage type don't pick one just hit ok that will leave you with a very basic install and when you reboot will leave you at the bash log in from there use aptitude to install what you want. I know that seems a bit vague i'm trying to dig up better instructions.
    these look ok. Except pick minimal package selection instead of mail server etc.
    http://linux.justinhartman.com/Installing_a_Debian_Etch_base_system
  8. Sir_Bill
    11 Feb 2009
    Thanks a lot for your reply!
    It's a pretty good guide!
    I found sth about freeBSD.
    What do you think?
    My big concern was when i had linux that i had to search 1.5 hours in order to find out how to install *.rpm packages to debian!
    I found alien and was trying to make that work.
    For someone that doesn't know the commands it's pretty rough.
    How am i going to make a shared folder available at my windows based machine so i can place there *.torrent files and (rtorrent i presume) takes them and downloads them?
    I assume that i need samba but if i don't know the basic commands how am i going to do sth more complex?:sigh:
  9. wsurritte
    wsurritte What's a Dremel?
    31 Oct 2005
    I'd use CentOS 5, Fedora 8 or ClarkConnect. All fairly easy to use Red Hat based distros.
  10. anupak
    anupak What's a Dremel?
    12 Feb 2009
    I am using a older motherboard (using DG201GLY2A) for torrents. I use fedora 8 (minimal install), torrentflux-b4rt. I did a few customization in configurations to make it headless. Been working without a issue for last 6 months.
    A few customizations I did were
    Webmin for headless admin.
    samba so I can share directly from the box (as it acts as a NAS).
    Few etc changes for unclean shutdowns
    few power saving customizations (using powertop).
  11. steveo_mcg
    26 May 2005
    What is it your trying to install from .rpm. These are RedHat packages you need a .deb for a debian based machine you're making live difficult for your self ;)
    At the prompt type aptitude and browse the package list this is a fairly comprehensive list of the packages available for debian and saves a lot of effort on google. Use the "/" to search aptitude, be warned however the names don't always make much sense.
  12. Sir_Bill
    11 Feb 2009
    I was trying to install APC Powerchute for my psu and it only comes as an .rpm package.
    I made it although to install it with alien, but it never worked.:grr:
    What about freeBSD?
  13. steveo_mcg
    26 May 2005
    pimonserry likes this.
  14. Sir_Bill
    11 Feb 2009
  15. davidfield375
    davidfield375 Hardware Mods
    3 Feb 2009
    I was going to set up a seedbox but then I bought a rapidshare account instead, much less hassle and also due to the files not being torrents, service providers can't block or limit the connections.
