Apple OS X Server vs OS X?
Discussion in 'Software' started by AT0MAC, 16 Jun 2010.
  1. AT0MAC
    AT0MAC Pirate Captain
    8 Jun 2008
    I'm wondering what the big difference is between OS X Server and OS X - IF you want to use it as your primary computer.
    a)
    Is the Server version a kind of add-on to the usual OS X, so you can just turn off all the sharing and extra security to get to the basic OS X?
    or...
    b)
    Is it a true Server OS that only makes a point if you really want to setup a server?
    and...
    c)
    If I buy the newly announced Mac Mini Server (the slim unibody version), would I in case of b) are the right answer be able to install the usual OS X, bought separately of course, to use it as a normal Mac Mini?
    ...as long there are no Blu-Ray in the thing I don't have anything to use the optical drive for, but much to use the extra harddrive space to.
  2. barry99705
    barry99705 sudo rm -Rf /
    20 Apr 2008
    OSX Server is a bit different than standard. Part two is true, really no point to run server os on a desktop unless you need the server parts. You'll never see Blueray on a Mac. Yes, you can install standard OSX on a mini bought with server.
  3. AT0MAC
    8 Jun 2008
    I put this question up in three different fora troughout the web - and you are the only person who nailed the reply I had hoped for :rock: rock on!
  4. jrs77
    jrs77 Modder
    17 Feb 2006
    Damn those sneaky /b/tards at Apple released a new macMini without any real announcements...
    Looks damn sexy :eeek:
  5. Tom @ CCL
    Tom @ CCL AKA: Yewen
    10 May 2010
    There are announcements all over the web, unboxings and dismantlings etc.
  6. AT0MAC
    8 Jun 2008
    Yep, only one thing I could really use is missing - a performance chart compared to earlier models.
    If I don't find it I might end up buying one and pumping the web full of whatever rating I can digg out of the small thing.
    If anyone see a performance rating of the new mini's would they be happy to share?
