Outlook 2007 problems
Discussion in 'Software' started by hw007, 5 Aug 2008.
  1. hw007
    hw007 What's a Dremel?
    31 Jul 2008
    Hello,
    Been haveing this problem with Outlook 2007 for the past few days, up until now it has been all ok, have done a search for this on the web, but so far I can't find anything that might help me solve it. Others are also having similar problems.
    When I hit the send/receive button, all the configured accounts are added to the task list in the send/receive window. After all account are processed, all accounts are added to the task list again for sending, over and over again. I have a screenshot of that on
    http://www.raadselweb.net/temp/sendreceive.jpg
    The above is not my screenshot, but this is exactly what is happening to me as well.
    If anyone can help I would appreciate it as I'm banging my head on a brick wall trying to find a solution :wallbash:
    Thanks
    Hitesh
  2. MixWizard
    MixWizard What's a Dremel?
    16 Jan 2007
    Have you got all the latest updates for it?
  3. hw007
    31 Jul 2008
    Yes, got SP1 installed for Office and SP2 installed for XP
    Hitesh
  4. MixWizard
    16 Jan 2007
  5. hw007
    31 Jul 2008
    Well that seems to have solved the problem, thank you very much
    Hitesh
