Windows outlook express 6
Discussion in 'Software' started by 24giovanni, 27 Jun 2006.
  1. 24giovanni
    24giovanni Banned
    10 Jun 2006
    When I open up outlook express, I can not see the "x" to close out. What can I do to fix this? I appreciate any help.
    Also, when I setup myself as a contact, I just see my fisrst name not my full name when I send mail to someone. How do I fix this as well.
    TIA
  2. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Maximise? Can you see the vertical scroll bar? :confused:
    Tools/Accounts/(select one)Properties/General tab.
    But the account name is not what shows at their end, they'll see the stuff from the User Information section.
  3. 24giovanni
    24giovanni Banned
    10 Jun 2006
    thank you. that was it.
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    If 'Maximise' fixed it, put it back to the other size, drag the whole window to one side so you can grab an edge or corner, and narrow it down a bit. That way it won't do it again.
  5. Krikkit
    21 Jan 2003
    Don't forget to maximise and then re-window-ize again, sometimes they don't remember if you just close it. :)
