Windows Outlook Express / IE Problem
Discussion in 'Software' started by Arthur2Sheds, 19 Nov 2003.
  1. Arthur2Sheds
    Arthur2Sheds Jackson
    19 May 2003
    Every time I click on a link in an email in Outlook Express, it reuses whatever browser window I currently have open. I looked in the Options section, and it says that Express just pulls your settings from whatever you have in IE. In IE, under the Advanced Options tab, I have 'Reuse windows when launching shortcuts' unchecked. Both Express and IE are version 6.028, latest updates, etc. I'm confused, please help? Thanks.
  2. Nigel
    Nigel What's a Dremel?
    7 Mar 2003
    Hmmm, there's an option somewhere that allows you to specify how many 'instances' of IE can be run at any one time. I too have the latest IE update but having a quick look just now I can't spot it.
    If your setting is only to allow "1" instance then it will renew the same window, if it is say five, then you will spawn up to five instances before anything overwrites.
    Sorry I can't find the setting at mo... (goes off to look again...)
  3. ajack
    ajack rox
    17 Apr 2003
    Personally I just copy link location and paste into broswer but not sure how to do it by opening the url
  4. HellDiver
    HellDiver What's a Dremel?
    31 Aug 2003
    It's just a crap program. Outlook did the same until Outlook 2003.
  5. cpemma
    cpemma Ecky thump
    27 Nov 2001
    I get multiple tabs clicking multiple email urls - using OE6/Firebird :D
  6. Arthur2Sheds
    19 May 2003
    Thanks, I'll see what I can find.
  7. Arthur2Sheds
    19 May 2003
    Went through every dang option and couldn't find it. I even searched in the registry. I don't think that's it, though, because in some emails links will open if I just hold the Shift key while clicking, and in others (formatted the same, from the same sender, etc.) won't open in a new window even if I beg and threaten. Any other ideas? Thanks!
