Windows Outlook Help
Discussion in 'Software' started by Gabe, 26 Mar 2005.
  1. Gabe
    Gabe What's a Dremel?
    19 Jan 2005
    on outlook if you have like for example, 3 accounts... how do you make it so it downloads each messages received to its own folder to seperate from each account so it's more organized instead of all account emails going into the same inbox? i'm using outlook 6.0
  2. trigger
    trigger Procrastinator
    22 Mar 2004
    You could set up some rules to say whenever a message is received that has been sent to abc@123.com move it to folder 123, etc
  3. Gabe
    19 Jan 2005
    how would i go on doing that? that sounds exactly what i want it to do
  4. trigger
    22 Mar 2004
    I haven't used Outlook in a while, but I seem to recall the rules setup is under the Tools menu, then you can just follow along the wizard to set the rules up as you need.
  5. monkeyville
    monkeyville Evilish Monkey ++;
    3 Aug 2003
    Yup its the rules wizard you want to look at. :thumb:
  6. Meblin
    Meblin Supposed IR God!
    5 Mar 2002
    setup a rule to work on the addresses coming in.
    • account1@blahblah.blah move to folder1
    • account2@blahblah.blah move to folder2
    • account3@blahblah.blah move to folder3
    • etc...
    Meblin
