Overclocking Overclock temps.
Discussion in 'Hardware' started by crosshair, 24 May 2011.
  1. crosshair
    crosshair It's life Jim but not as we know it
    12 May 2009
    Hi. Just overclocked my Core i5 2500K to 4.5GHz.:baby: Ran a stress test for five minutes using Prime95 and monitored temps. using CoreTemp.
    Temperatures peaked @ 68°C, but for the most part hovered around 66°C.:worried:
    Since it's only the Turbo Boost that's overclocked, are these temps. acceptable? I play mostly online games; Bad Company 2 being the most demanding, and that didn't exceed 58°C.:D
  2. TheStockBroker
    TheStockBroker Modder
    19 Nov 2009
    Not a direct answer to your question, but what voltage and cooler are you using as these make the temps quite subjective.
    TSB
  3. crosshair
    12 May 2009
    CPU voltage: 1.3
    Dark Rock Advanced.
  4. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    Not sure about voltages (don't have a SB CPU), but the temps seem acceptable.
  5. snooky32
    snooky32 What's a Dremel?
    29 Apr 2010
    I have the same cpu/mobo/cooler combination as you, and am getting very similar temps. Mine is at 1.34V Vcore, can't get it stable as low as 1.3V so you are lucky there.
    My understanding is that these temps are acceptable, I was looking to keep my temps under 70C with my overclock.
  6. jasonst888
    jasonst888 What's a Dremel?
    24 May 2011
    I agree with StockBroker, we need to know what voltage its at. The temps arent terrible...what cooler you got though, cause if it was me I'd say thats pretty high for standard use. And a stress test for 5mins isnt good enough, that ignores the build up of temp in the case, which will affect the core temp as well, even if under stress its at almost 70, overtime that could creep up.
  7. bulldogjeff
    2 Mar 2010
    Nothing wrong with those temps, If that was 20 degrees higher you'd have cause for alarm.
  8. crosshair
    12 May 2009
    Good good! Thanks guys, that's what I wanted to hear.:rock:
  9. mars-bar-man
    17 Apr 2009
    I've just seen what core temp has recorded my temps at.... :| I think I need to dial my OC back a bit...
  10. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    I'm 1.3V at 4.7GHz stable :D
  11. bulldogjeff
    2 Mar 2010
    Some one getting a bit toasty...lol
  12. mars-bar-man
    17 Apr 2009
    Nudging high 80's!! :O Prime95 and Intel Burn Test didn't even push them that high!
  13. bulldogjeff
    2 Mar 2010
    It'll take it, but I wouldn't be happy with it running that high.
  14. mars-bar-man
    17 Apr 2009
    Nor am I :/ in fairness I'm still on stock fans.. May have to invest in some AP's when I get back home.. Can't get my volts down anymore more either..
  15. Sponge12349
    Sponge12349 (づ。◕‿‿◕。)づ ︵ ┻━┻
    12 Apr 2010
    .oops didnt refresh
  16. NigelT
    NigelT What's a Dremel?
    30 Apr 2011
    I'm running my i7-2600k @ 4.7ghz. Temps momentarily peak at 70, usually 68 when encoding or rendering. Using dark rock advanced.
  17. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    i5 2500k @ 4.7Ghz w/ 1.35V using a Gelid Tranquillo and I usually sit around 65 degrees when folding. May have to push it a little more or get a wet cooler :p
  18. bulldogjeff
    2 Mar 2010
    Ahhh, That's the clincher. I thought you had a decent cooler fitted. So that about right then temps wise.
  19. jasonst888
    24 May 2011
    Just be careful, Silverstone TJ07 should vent well but might be worth doing some longer stress tests to see if the temp starts creeping up, dont know about you but when im up to something intensive on my rig, it rarely only takes 5mins!
  20. mars-bar-man
    17 Apr 2009
    Got the Gelid Tranquillo, but it's the stock LianLi fans. They don't move much air..
