Other Overclockers 'clearance line' any experience
Discussion in 'Hardware' started by onthejazz, 5 Mar 2010.
  1. onthejazz
    onthejazz What's a Dremel?
    17 Feb 2010
    Has anyone had any experience with overclockers 'clearance' or 'B' products?
  2. wyx087
    15 Aug 2007
    bought a B grade Samsung T240 from them a while ago, came with a battered box and blue colour not working correctly, posted in their customers support section and was able to get a refund.
    got refund and their "A grade" T240 became cheaper (just £10 more than the B grade i bought), so bought that instead.
    generally, if the item is not working, then they will give a refund, but buying B grade means you can't be fussy, you can't ask for refund because it's got a few cables missing.
  3. D-Cyph3r
    D-Cyph3r Gay for Yunosuke
    31 Aug 2008
    You can get some bargains (like when I got a 9800GX2 for £150 a year ago, only had an open box, hadn't even been used), but they can mug you off big time aswell (like when I bought what was labelled as a TJ07 and a TJ03 arrived at my door).
    Nowadays I just avoid OcUK in general, their borderline criminals in my eyes, if I need something cheap I head for the for sale sections on forums or ebay.
  4. Jipa
    5 Feb 2004
    Getting TJ03 instead of TJ07 isn't something you should put up with. B-grade means it has open box, battered box and maybe a few scratches, it doesn't mean that the product could be totally different from the description.
    Dunno about the OcUK in general, have just read on this forum, but that really applies to any and all stores.
  5. jbloggs
    jbloggs What's a Dremel?
    12 Sep 2007
    Recently bought a Linksys WRT54GL from their Clearance lines, it was boxed (although not original) with all the original parts...
    Have bought a lot of stuff of OcUK over the past few years and never had any problems; had some faulty ram that was DOA, but a simple case of sending it back and getting it replaced...
    I wonder if we are talking about the same "OcUK"...;)
    ________
    Laguna Heights Condominium Wong Amat
  6. onthejazz
    17 Feb 2010
    Which forums? I would be interested to know. Thanks
  7. balatro2005
    balatro2005 Minimodder
    19 Sep 2009
  8. jbloggs
    12 Sep 2007
  9. onthejazz
    17 Feb 2010
    Am I only allowed to access this store after 250 posts on OcuK, or just post products to sell?
  10. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    bit-tech has a similar one, once you have been here a while you get access.
  11. jbloggs
    12 Sep 2007
    To buy and sell in the member's Market on OcUK you need 250 posts and be a signed up member for at leat 90 days...
    ________
    WEB SHOWS
  12. GiGo
    GiGo was once a nerd.....
    12 May 2002
    Had a few items from there B grade section, mainly just means open box / returned product / missing connectors and calbes etc...
    They are tested before they give them to you. Some times they have a real bargains.
    Regards
    GiGo
