Hardware Overclockers UK Titan Agent 47 Review
Discussion in 'Article Discussion' started by Dogbert666, 5 Apr 2016.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  2. Hustler
    Hustler Minimodder
    8 Aug 2005
    Looks very nice...even if I continue to refuse the logic of a MiniITX case that big.
  3. Splooshiba
    Splooshiba Minimodder
    20 Jan 2012
    Very nice but I wish those GPU power cables were tidied away!
  4. David
    7 Apr 2009
    Another Titan in name only. Stupid name is stupid.
    I can't really compare the majority of benchmarks, but the Valley score seems awfully low - my stock speed 6600K with a GTX 780 scored significantly higher than that.
  5. Vault-Tec
    30 Aug 2015
    I find it a little confusing. The only instance in which I would accept an ITX case that size is if I was using water cooling. Which it doesn't, not even a single AIO.
    You could get that spec into a case nearly half that size.
  6. Hustler
    Hustler Minimodder
    8 Aug 2005
    I think I've commented on it before but this case gives you all the limitations of MiniITX form factor with none of the small size benefits.
    What..is..the..point?
  7. Vault-Tec
    30 Aug 2015
    Yup exactly. Now if they fitted a decent AIO to the CPU and one to the GPU this rig would make a lot more sense.
    I struggle to see how any one could find this case attractive. It looks like it used to be square but some one gave it to Lenny and he fitted some of his insane fans to it and blew it up like that.
  8. Taua
    Taua What's a Dremel?
    20 Sep 2014
    1.3vcore for 4.5? I guess it's a set and forget kinda thing, unless skylake is somehow tougher than haswell.
    Also, that case needs to die, it's pointless and horrible and it needs to die.
Tags: Add Tags
