Overclocking 2500+ on air...
Discussion in 'Hardware' started by tmod, 27 May 2004.
  1. tmod
    tmod What's a Dremel?
    9 Apr 2004
    What do you think is the highest stable OC possible with just air cooling for an XP-M 2500+? I'm thinking about getting one for my second gaming rig. Thanks.
  2. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    read the dfi, pifast, winrar, and superpi threads around here, you will learn eveything you need to know.
    ps. about 2.8ghz with a lot of hard work.
  3. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Kam's managed to hike his up to about 2.7 ghz with just air cooling, but thats realy good air, murdoc has reached about the same with air but that was with a cache unlocked thorton....
  4. Dodge
    Dodge What's a Dremel?
    10 Oct 2003
    I got mine to 2.5, yodasarmpit has had his slightly further i think. If i remember correctly, he got it to 2.7, but that was anything but stable
  5. olv
    olv he's so bright
    23 Sep 2002
    Most speeds that have been quoted are only bench stable and by no means Prime95 stable. From experience with mine i'd say its easy to get them up high bench stable 2.7GHz+ but getting them fully stable is much more difficult (but that may just be my rig). 2.6ghz is attainable 2.4-2.5 should be quite doable. All depends on the setup and the chip.
  6. unclean
    unclean SMP obsessive
    30 Dec 2003
    should an aircooled setup that gives me 49/50degrees underload w/1.9vcore be able to cope with getting a mobile to ~2.7ghz?
  7. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    You should be looking at 2.4GHz - 2.5GHz stable.
  8. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Where can you buy this really good air, Im fed up with the stuff Im breathing right now :D
  9. Gecko
    Gecko What's a Dremel?
    29 Dec 2003
    What about that bottled air shops sell? I bet thats really good air :D
  10. Highland3r
    25 Jul 2003
    Just goto Tesco's m8, wonder up to the customer services and ask fior their Tescos finest air, tesco value is carp.... :p
  11. jetsetjimbo
    jetsetjimbo Up-up and away
    19 Feb 2003
    2.8 on air :jawdrop: That's really going some - must have their own personal hurricane :hehe:
    Mind u gess it depends on the voltage / temps you're willing to push...
  12. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    I managed 2.8GHz on water, and it was stable, well the BSOD was stable anyway
    http://www.yodasarmpit.co.uk/pics/m2500/2818a.JPG
    System crashed less than 5 seconds after taking this
  13. k3nn
    k3nn What's a Dremel?
    2 Feb 2004
    spot on, ive got mine a 2.4(200x12) running perfect, never had a problem, running with a volcano 9, so its not cooled to any great extent, 47 idle, 53 loaded, with a nice 1.7 core volts.
    I would imagine with some better air cooling such as a heat pipe(thermalright me thinks) and a big assed 92 mil fan it would get to 2.5 easy. also depends on the voltage you're having to run it at.
  14. rio2
    rio2 What's a Dremel?
    8 Apr 2004
    for continued use max 2,4-2,5 ghz is consigliated i use hair system for my(look the sign) :thumb:
