Overclocking 4850
Discussion in 'Hardware' started by CanadaPhil, 4 Sep 2008.
  1. CanadaPhil
    CanadaPhil What's a Dremel?
    12 Aug 2008
    I'm thinking to buy a Sapphire 4850 with stock cooler just because it's available. I'd really like to buy the toxic version, but nobody seems to be able to keep it on the shelf.
    If i buy the stock version and want to overclock it, how difficult is it to change out the coolers? Is it just a matter of a removing few screws to get the casing and cooler off and then apply the new cooler? or is it more complicated? Can anybody recommend a good aftermarket GPU cooler? Can I use my old CPU cooler on my GPU?
    Thanks,
    Phil
  2. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    your cpu cooler wont work. they dont mount the same way.
    Its not hard to replace the stock one, just unscrew, apply paste and pu the new one on.
  3. CanadaPhil
    12 Aug 2008
    What is a good after market GPU cooler?
  4. yanglu
    yanglu Hmm...
    20 Aug 2008
    Why don't you go for the Sapphire HD4850 with a DUAL SLOT cooler. It amazingly costs the same as the stock HD 4850 but runs much cooler and overclocks to the same speed as the Sapphire toxic 4850
  5. Akava
    Akava Lurking...
    28 Jul 2007
