Overclocking 64 Bits
Discussion in 'Hardware' started by Ready2GoXtr, 4 May 2004.
  1. Ready2GoXtr
    Ready2GoXtr What's a Dremel?
    29 Mar 2004
    Is it realy ever worth it to overclock a 64 bit to the max and if you did, what would you need to keep it cool
  2. Langer
    Langer Jesse Lang
    24 Jan 2004
    I was just about to pst this thread, I'll be looking forward to hearing the replies
  3. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    As worth it as a standard 32 bit chip, nb: the a64 is a 32bit chip with 64 bit capabilities.
    A decent air cooler, water, or frost.
  4. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    On air I can get my FX51 (2.2ghz) up to 2.5Ghz stable.
    Bigz got his FX53 pretty high in his review.
  5. Pookeyhead
    30 Jan 2004
    I routinely run at 2.4GHz without much effort. I run into problems due to my disk controller after that. If it wasn't for that I could go way higher I imagine. My temps are around 32/42 (idle/loaded) at 2.4GHz on air, so yes... it's well worth it.
