Overclocking Overclocking HD5770
Discussion in 'Hardware' started by GingerFox, 4 Jan 2010.
  1. GingerFox
    GingerFox What's a Dremel?
    15 Nov 2009
    Anyone got one that they have overclocked? If so what did you get it too?
    Just a general wonderence to see where i might be able to get mine to:)
  2. Bloodburgers
    Bloodburgers Minimodder
    30 Apr 2009
    have you tried using the catalyst auto utility or riva tuner?
  3. LithiumDesign
    LithiumDesign 3dsMax User
    23 Jul 2009
    Using ATI Overdrive:
    Dunn if it is good or not but its stable, the fans is a little loud though :p
  4. GingerFox
    15 Nov 2009
    It maxes out in overdrive (well the gpu does, i got bord of waiting for the memory to slowly bench) so i was wondering about out of overdrive?
  5. Guest-44432
    Guest-44432 Guest
    Unless you are using water cooling to keep those temps down I would not bother overclocking, as it don't give you that much of an improvement. 1-2fps. Hardly worth burning out your card for.
    Simon
  6. TheHalfWit
    TheHalfWit Call me dino
    25 Aug 2009
    I've got mine stable at 900gpu and 1300 for the memory, my rooms just a little hot at the moment, I had it downstairs where its probably around 10 degrees c colder and I had it running stable at 1ghz on the gpu and 1300 on the memory.
    note: I adjusted the voltage a bit to get it to run at 1ghz.
  7. GingerFox
    15 Nov 2009
    Aha very helpful, what program did you use to adjust the voltage? (not that i would sounds risky, but out of interest)
  8. Des0lution
    Des0lution What's a Dremel?
    13 Mar 2010
    Download MSI Afterburner, edit the config file from... EnableUnofficialOverclocking = 0 to =1
    I've overvolted mine to 1.3v and have currently got gpu clock at 1ghz and memory clock at 1450mhz, 3 runs of crysis benchmark on very high, max temp 63 degrees, with stock cooler
    have found a waterblock for 50(GBP) might invest ;)
