Overclocking Overclocking problems.
Discussion in 'Hardware' started by BiotecVirus, 26 Jun 2010.
  1. BiotecVirus
    BiotecVirus Everything should use Torx Screws
    10 Jun 2010
    Hi, I was wondering if anyone could help me.
    I've been trying to overclock a Intel core 2 duo E6750 @ 2.66ghz up to 3ghz, but so far attempts at even overclocking it to 2.67ghz causes the 8x multiplier to roll back onto 6x where it will stay even under full load reducing system performance. To try and stop this I need to turn off speedstep technology but on my foxconn motherboard BIOS options I can't find this as a option so I can't turn it off, will it be hidden under another option possibly?
    My system specs are...
    • Intel core 2 duo E6750 2.66ghz
    • 4GB of DDR2 ram
    • 2x maxtor 500GB hard disks
    • XFX radeon 5830
    • Foxconn ELA Intel P45 (Socket 775) DDR2 Motherboard [ELA]
    • Windows 7 64 bit
    Thanks for all help.
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Not usually, its just called SpeedStep. Can you give me the full model number so I can look up the manual.
  3. Shadow703793
    Shadow703793 What's a Dremel?
    5 May 2009
    The multiplier should go back up to 8x with an intensive work load (ie download OCCT and run Linpack).
    Download RealTemp and check your temps. When the C2D/C2Qs,etc start overheating, it will automatically go to 6x to reduce temps.
  4. BiotecVirus
    10 Jun 2010
  5. Bloody_Pete
    11 Aug 2008
    This should be it: ' C1E Function
    C1E represents Enhanced HALT State. It is a feature which Intel CPU uses to reduce power
    consumption when in halt state. C1E drops the CPU's multiplier and voltage to lower levels
    when a HLT (halt) command is issued. This item is used to enable/disable the C1E support.' From the manual. The other thing it could be is EIST (Enhanced Intel SpeedStep® technology). Just try disabling both under the CPU Configuration menu in Gladiator BIOS.
    Hope this helps :)
  6. BiotecVirus
    10 Jun 2010
    turned em both to disabled and increased the speed from 333 to 350 e.g. 2.80GHZ, windows seems to have relised this (under system info) but cpu-z only reports 2.09GHZ as the mutiplier has rolled back to 6x.
    Linpack reports a -21% underclock becuase of this.
  7. murraynt
    murraynt Modder
    6 Jun 2009
    run something like orthos while using cpu-z and you will see it at full speed
    Also i dont know if it is a me thing or windows 7 thing but windows applications will always show my cpu(E6750 )at 2.66 ghz
  8. Bloody_Pete
    11 Aug 2008
    CPU-z uses live reporting. But if they're disable it shouldn't be dropping the multiplier at all.
  9. BiotecVirus
    10 Jun 2010
    IT still dropping mutiplier. Did it when it was on vista as well
  10. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    20 degrees seems a bit optimistic with only an ACFP7.
    What are you measuring the temp with??
  11. BiotecVirus
    10 Jun 2010
    speedfan. what really helps with the cooling is no case :) pretty much no heat. inside a case it was around 38C
  12. BiotecVirus
    10 Jun 2010
    so anyone knows what else may be causing the issue?
