Overclocking Overclocking Q6600 on Asus P5K-E/WIFI-AP
Discussion in 'Hardware' started by leebarros, 31 Jan 2010.
  1. leebarros
    leebarros What's a Dremel?
    2 Jun 2009
    Hello,
    I recently upgraded to Windows 7 Ultimate 64bit and I have noticed that my Q6600 is sitting at the stock speeds in CPU-Z...then all of a sudden the multiplier drops from X9 to X6 and goes back and forth between these.
    I recently overclocked it to 3.4GHz using the guide in CustomPC last month and it worked fine and this was under Windows Vista Ultimate 64bit
    Now when I try and overclock it, it either goes to the correct speed and then drops down again due to the X6 multiplier or it just refuses to boot.
    Anything I should be doing?
    Cheers :thumb:
    -Lee
  2. Fazed
    Fazed Minimodder
    5 Jul 2009
    Have you checked the Power Saving option with Win 7's control panel?
    All corect drivers Installed? Cleared CMOS and re-applied overclocks?
