Overclocking Results: Super-PI Challenge! (please read the first post)
Discussion in 'Hardware' started by Tim S, 8 Sep 2003.
  1. olv
    olv he's so bright
    23 Sep 2002
    You will have to do a lot to nock 8 seconds of your time!
  2. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    Nice 32s! I have a buddy who i'll have to get to post here. Got 46s on a 2500-M @ 2.5, SC DDR333. I'll also get him to re-do once he gets some D-400.
  3. Tim S
    Tim S OG
    8 Nov 2001
    I was thinking the same, especially since I'm getting a cooling upgrade soon ;)
  4. cderalow
    cderalow bondage master!
    23 Jan 2002
    yours doesn't count as its a -M processor!
    and i've yet to put my watercooling back in :p can't imagine if i actually hooked it up to my prommy
  5. Tulatin
    16 Oct 2003
    hey, don't knock the Ms. They're the same thing. Esp with 1.7v and under 40c load (slk 900u+tornado 92)
  6. Tim S
    Tim S OG
    8 Nov 2001
    errrr, it's built on the same core technology.... and has the same cache. It's just better silicon so can run higher clock speeds with the same voltage. Therefore it's a barton 2500+ surely?
  7. Tulatin
    16 Oct 2003
    Technically. Or we can call it a Barton 2500++
  8. olv
    olv he's so bright
    23 Sep 2002
    we should discount people with annoyingly good steppings as well, as they dont count either :p (i'm just bitter with my **** 2400 lol)
  9. Tim S
    Tim S OG
    8 Nov 2001
    oh and also I got 38s with my 2500+ IIRC before I sold it... good luck beating it!
  10. cderalow
    23 Jan 2002
    ah but the idea is to post your current processor, not what you had
    and yours is a 2500+ -M meaning it has a lower heat output if i remember right as well... its still not a regular 2500+
  11. Mister_Tad
    27 Dec 2002
    a 2500M is no different to a normal 2500
    it is the same as buying a good stepping of a processor because it overclocks well
    same processor, just most the element of luck regarding its overclocking is removed, and you are pretty much garaunteed a good clocker
    surely the idea is to post different results with different processors, for comparison purposes
    next you are going to start saying that people with BH5 cant post results, because it is very good ram and you cant get it any more :rolleyes:
    </rant>
  12. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    This is a little discouraging. 300+ mhz overclocked and no improvement???
  13. olv
    olv he's so bright
    23 Sep 2002
    from the looks of it it looks like you have loads of crap running in the back ground which will seriously slow it down.
  14. TekMonkey
    6 Dec 2002
    I don't have loads of stuff. I don't think I have anything extra running than on my first test. I would have expected it to have increased even with stuff running
  15. TekMonkey
    6 Dec 2002
    I disabled every service possible and all programs
  16. olv
    olv he's so bright
    23 Sep 2002
    see a 5 second increase is pretty huge. You need a much higher fsb and tight memory timings to get lower. Also most of the guys running high 30's, low-mid 40's will be running on fresh windows installs
  17. TekMonkey
    6 Dec 2002
    I don't want to boost my FSB too much untill I get propper cooling. As for the memory timings, how do I improve those?
  18. olv
    olv he's so bright
    23 Sep 2002
    In BIOS, not sure what it will be under for you but looks for Memory settings or timings. It may be set my SPD now you want them as small/tight as possible. You will probably need to boost the volts to the ram and it may not like tighter timings at all. Theres a big thing about it in the FAQ
  19. cderalow
    23 Jan 2002
    only its not the same processor...
    its meant for an entirely different application, its got a lower heat output than a regular Barton 2500+
    When i say current processor, I mean the one he's using right now, note, when i changed processors, I no longer continued to keep thinking of my XP2200+ as being the fastest one there was because i wasn't using it as my main system anymore... the idea is to post different processors in different systems, not the same processor in the same system, if the idea was to do that, I'd run all of my chips in my prometia and would have almost the exact same times across 3 different XP chips...
  20. olv
    olv he's so bright
    23 Sep 2002
    I thought the point of this thread was for showing off/bragging rights?
    a mobile barton is exactly the same as a normal barton but it has been hand picked to run stable at 1.45v which gives it its lower heat output. How is buying one of them any different from buying a normal barton with a decent stepping? it's exactly the same core etc blah blah you are just buying it for a specific quality, as is with steppings...
