Overclocking Results: Super-PI Challenge! (please read the first post)
Discussion in 'Hardware' started by Tim S, 8 Sep 2003.
  1. Mister_Tad
    27 Dec 2002
    just thought that id add my latest contribution
    specs in sig, ram timings 3-2-2-6 1:1
  2. Rys
    Rys What's a Dremel?
    21 Sep 2004
    28 seconds. Click here for the fullsize version.
    FX-53 on S940, 3023MHz @ 13.5 x 224, ASUS SK8V, Vcore mod, 1GB of Corsair XMS3500RE @ 224MHz, 2-3-2-6.
    The XP install was a fully working copy, loaded with apps, that I used 24/7 @ 3GHz for a good month or so.
    :rock:
    Rys
    EDIT: VapoChill LightSpeed (first rev, 250W version) on the CPU too :thumb:
  3. Kensei
    Kensei What's a Dremel?
    26 Sep 2004
    Well, here's mine:
    AThlon FX 53 (939)
    2Gb Hitachi DDR400 3-3-3
    MSI NEO2 Platinum (Nforce 3) Mobo
    Sapphire Radeon 9800Pro (Stock)
    2x 74GB raptors.
  4. Mister_Tad
    27 Dec 2002
    wrong screenshot mate
    you need superpi just after it has run with the times to complete each individual loop
    Rys- you forgot to list the cooling
  5. Rys
    21 Sep 2004
    Edited to fix, sorry about that.
    Rys
  6. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    Another second shaved off :)
    xp2400+ (cooled with CM Aero7+), Geil Ultra PC3200 (Cl2.5 :( rated at 2 but motherboard doesnt like it)
  7. Mister_Tad
    27 Dec 2002
    my experience with geil ram has been that it sometimes like a little extra voltage to run its rated timings, what are vdimm you running?
    Ive needed to use as much as 2.8v just for its rated timings/speed
  8. Mister_Tad
    27 Dec 2002
    me again
    same timings etc as before
  9. unclean
    unclean SMP obsessive
    30 Dec 2003
    Please govn'r.
  10. Mister_Tad
    27 Dec 2002
    ask me again and im leaving you out of the next update
    ill update the table when im good and ready, i dont sit on the forums 24/7 waiting for new posts here you know :thumb:
  11. unclean
    30 Dec 2003
    Jeez, i just figured that you had missed the post as there was no acknowlegement of it.
  12. Mister_Tad
    27 Dec 2002
    i do not acknowledge every post in this thread, there is no need.
    If i said "cheers ill make note of that one" after every new time it would be awfully cluttered not wouldnt it?
    when i upddate a go through post by post and update the excel file appropriately, so i wont miss a post.
    on the last update the image in your post was down, and now there is no indication of the ram timings or the cooling you used, both of which are required in the table, if you can get those listed i will try to make sure you are included in the next update
    and learn some manners :thumb:
    its not just you by the way, ive had plenty PMs saying "oi update the table" from people within a few days of their post.
    FAO all
    I do not upate the table with every new post, once a certain number of posts have been made (at my discresion) or a certian amount of time has passed, the table will get updated
  13. renimatorius
    renimatorius What's a Dremel?
    14 Jul 2004
    AMD 2500+
    DFI LANPARTY NFII ULTRA B
    Kingston Hiperx 512 kit 2-2-2-8
    SPIRE WhisperRock IV
    Geforce2 MX 400 :hehe: :hehe:
  14. Mr T
    14 Nov 2001
    Yea i tried that :( its at 2.9v :(
    Edit: After some testing it seams to be running ok now at CL2 but only time will tell :(
  15. Miraz
    Miraz What's a Dremel?
    9 Jul 2004
    AMD Athlon 64 3500+
    MSI K8N Neo2 Platinum nForce3 v1.3 Bios
    Stock HSF
    Corsair 3200XL – 1T 2.5-3-3-8 @ 2.8v 1:1
    A LOT of thanks to some people on this forum for your help.
  16. Mortus
    Mortus What's a Dremel?
    30 Sep 2004
    Not bad for an XP2500 i dont think anyways :)
  17. Andrewv
    Andrewv What's a Dremel?
    21 Mar 2004
    New stable OC with new Superpi 1m mark
    40s
  18. Tim S
    Tim S OG
    8 Nov 2001
    A64 FX-55 @ 13x211, 1.75v
    1GB Corsair 3200XL @ 211MHz 2.0-2-2-5
    MSI K8T Neo 2 mobo
    I might have to get the EB out :D
  19. Mister_Tad
    27 Dec 2002
    i might have to bitchslap you if you do :p
    not a bad time for stock cooling though :thumb:
    (that is on stock cooling yeah?)
  20. Tim S
    Tim S OG
    8 Nov 2001
    yep, everything stock, no mods, stock cooler, etc, etc :)
    I tried 226x12, and kept getting errors... so I have a feeling that it's TCCD related - I've not tested TCCD on an Athlon 64 before, but I have heard that it doesn't perform as well on A64 as it does on a Pentium 4 chipset.
