Overclocking Results: Super-PI Challenge! (please read the first post)
Discussion in 'Hardware' started by Tim S, 8 Sep 2003.
  1. TMM
    TMM Modder
    12 Jan 2004
  2. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Nice, what LDT are you able to run on that Abit?
    incase anyone needs them superpi, and the sse2 and sse3 patches are uploaded here. Process timer is there as well, gives a slightly more accurate timing. SSE3 patch is for the Prescotts :)
  3. TMM
    TMM Modder
    12 Jan 2004
    with the cpu at a 5x multi and the ram at "266" (4:6~ dram:htt), i was able to boot into windows at 290HTT with the LDT at 4* and i ran prime for 30mins fine until i got bored and stopped it :D (not sure how much this stresses the NB due to the Athlon64 design though....)
    I haven't tryed more then 290 yet, as im trying to sort out a problem with my ram (doesn't like much over 227mhz in dual chan.. this also happened on my Nf7-s, so im 99% sure its the ram and not the mobo.)
    Edit:
    I just got into windows at 305HTT with the LDT at 4*, though it locked up pretty soon after the welcome screen loaded. moving the LDT down to 3* had no advantage, i couldn't get into windows at anything over 305, though it POSTed at 310.
    Edit2:
    33seconds now, and with lower clock speeds :)
    [SSE2 patched]
    3200+ winchester, 1.53v~
    2x512 kingmax 3700 @ cpu/11 divider, 2.5-3-3-7 1T
    thats it for now, i played with 1.6v on the stock HSF but lets just say it was a little toasty :D... i think i'll wait untill i get something a bit better..
  4. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    Patched and unpatched.
    I'm completely stuck, can't get this thing to bench at 2.6GHz :( The board won't run the ~320HTT I'd need to have my RAM running at it's fullest on a 166 divider either, it'll do 270+ 2-2-2 1T at this rather worrying voltage:
  5. Kameleon
    29 Apr 2003
    Yay, double post!
    Managed an improvement but the patched version wouldn't run error-free :blah: I'm burning in some more, this thing WILL get to 2.6 :grr:
  6. Tolsk
    Tolsk What's a Dremel?
    14 Jul 2004
    Ummm i had it on 1.65v
  7. TMM
    TMM Modder
    12 Jan 2004
    :( you must just have a bad chip then, or your mobo/ram won't do the HTT/fsb.. but it should. im assuming you were running your ram on a divider?
    edit: also try setting your LDT down to 4x or 3x, that should keep things a little more stable when running higher HTT
  8. Tolsk
    14 Jul 2004
    pc3200 corsair should be able to take a 210 fsb. i mean seriously
  9. Highland3r
    25 Jul 2003
    Can you post an A64 tweaker screengrab please :D You might be running some timings too tight or summit.... linky if you need it
  10. Highland3r
    25 Jul 2003
    modded version of superpi available (see below thread)
    download it here
    This WASNT modded by me. There should be sse2 and sse3 versions on the way. Makes thee effects of changes much easier to see, without having to use the process timer. This DOESNT affect the overall pi time.
    http://www.xtremesystems.org/forums/showthread.php?t=54289
  11. Tolsk
    14 Jul 2004
  12. TMM
    TMM Modder
    12 Jan 2004
    try setting the cas to 3 and give it some more volts, 2.8v should be plenty for now (if you haven't already done so)
  13. tank_rider
    tank_rider What's a Dremel?
    3 Feb 2005
    Athlon XP 2600+ 185MHz FSB 11.5x multpilier
    PCChips M852 K7 KT400 Mobo (yeas i know its poo too)
    Ebuyer value 2700 RAM (yes i know its poo) at 2.5:3:3:7
    not bad for a poor mobo and ram :)
  14. Sniper man
    Sniper man What's a Dremel?
    18 Dec 2004
    I cna't currently post a pic but how is this?
    P4 2.8 prescott oc'ed to 3.5
    IC7G mobo
    1gb dual channle xmx pc3200 corsair
    It did a 37 but I had all my spyware programs running. Good or bad?
  15. copycatuk
    copycatuk What's a Dremel?
    10 Jun 2004
    managed to get this a few minutes ago
    will have a bit more of a fiddle tomorrow and try and get below that 32s barrier (if i can) :sigh:
  16. Highland3r
    25 Jul 2003
    Nice time :D
    What cooling are you running though? 1.775v seems a tad (or a lot) on the high side for a winny....
  17. copycatuk
    10 Jun 2004
    air cooling :eeek:
    only had it at that speed for 5 minutes while i tried pi and that was my first attempt so when i finally get some decent cooling ill see if i can get higher :D
  18. -x-hellfire
    -x-hellfire What's a Dremel?
    25 Feb 2005
    does the Super-PI indicate how fast the computer will be at raytrace rendering in 3D Studio Max 7 ?
    price / performance ratio
    ...as for setting up a rendering farm, less cpu power * more cpu:s in a network and regarding powerconsumption and noise pollution if air cooled
  19. overcrash
    overcrash What's a Dremel?
    9 Mar 2005
    Processor: A64 3000+ 939 0.09µ
    Motherboard: DFI NF4 Ultra-D
    Cooling: WC Home made
    Memory; Corsair PC3500 BH5 Chips 2-2-2-5 3.7v
    (no opti no pached ,just for test ,i'll retry in 2 week to take 27s :D )
    then with just less optimization at 2700 Mhz 30s ;)
    30s 2700Mhz RAM desynch to 270Mhz
  20. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    Woah, nearly 3Ghz :eeek:
