Overclocking Results: Super-PI Challenge! (please read the first post)
Discussion in 'Hardware' started by Tim S, 8 Sep 2003.
  1. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Thats a damn fine winny you got yourself there!
    Are you running any os tweaks at all? Might be possible to shave another second or so off that time...
  2. Mister_Tad
    27 Dec 2002
    very nice time :thumb:
    finally for some *real* competition ;)
    im quite confident on shaving off another second to get 29 but 28 may be stretching it, let alone 27 :blush:
    what sort of home-made cooling are you running?
  3. overcrash
    overcrash What's a Dremel?
    9 Mar 2005
    not any tweak just kill process unusual :D i can do 27s but with a few optimization :thumb:
    this but when i've do superPI the WC was stay inside ,i'll retry with the WC outside in 2 weet (i havent time for the moment) then i'll optimize more to do 27s with superPI not pached :D
    same disposition with my old DFI NF3 :D but now with my NF4 ;)
    i can do better with my WC outside in 2 week :D
    have you an CPUMark database :confused:
    for this :D CPUMark 362 2990Mhz
  4. TMM
    TMM Modder
    12 Jan 2004
    yeh baby 1.72v :p (man this thing needs alot of voltage :/ )
    [sse2]
    mem @ cpu/12, 2.5-3-3-6-9-11 (no idea but setting the tras lower then cas+ras to cas + 2 seems to boost performance :eyebrow:
  5. tiido
    tiido What's a Dremel?
    10 Mar 2005
  6. Razor_cut
    Razor_cut What's a Dremel?
    12 Mar 2004
    29sec :thumb:
    3200+ 0.09
    MSI NEO2
    OCZ 3200 Rev.2 (1Gb)
    But will try 27 when my LS rigg gets ut going. The result above is cooled with -6C air and SLK948U+Delta 8cm.
  7. Mister_Tad
    27 Dec 2002
    Can everybody please use the superpi that gives the times to 3 decimal places to participate
  8. Highland3r
    25 Jul 2003
    here
    Incase you need it.. It should be kept up to date as new versions are released
  9. Mister_Tad
    27 Dec 2002
    also updated the first post in the thread to include the same link :thumb:
  10. fathazza
    fathazza Freed on Probation
    20 May 2002
    least it got under 40 ;) having issues with getting my ram to evern function at its rated speeds in this board
  11. JuMpErFLY
    JuMpErFLY Minimodder
    13 Mar 2003
  12. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    This is just a tidbit for those of you with Nforce 4 boards; they seem to like the timings of 2,2,2,7 best for optimal performance. I dont have a board to try this on, but give it a go if you're so inclined :thumb:
  13. tank_rider
    tank_rider What's a Dremel?
    3 Feb 2005
    my latest attempt with my new NF7-s mobo and OCZ Prmier RAM running 1:1, 2.5-3-3-7 timings, the new mobo has allowed me to get a respectable 400MHz overclock using air cooling.
    Pretty pleased with the improvement of nion 9 secs over my previous setup.
    I had the time down to 45 secs, but didnt get a screenshot of it, that was with the processor at 2400MHz and the RAM timings relaxed.
  14. jsheff
    jsheff What's a Dremel?
    24 Jul 2004
    Okay, so I'm a long tme reader, first time writer. Well, second but that was a while ago. Here's my result from my Toshiba Portege m200 Tablet PC with a Pentium M 745 (Dothan @ 1.8Ghz) at a shade under 2.4Ghz: 35.648secs.
    The desktop res is a tad high being the tablet's native res.
    I like that score :)
    The tablet uses an Intel i855PM, 512MB of Samsung DDR1 memory at 220Mhz, Windows XP Tablet PC Edition 2005 OS, Memory divider of 3:5 and all using STOCK cooling. Yeah - that's right, stock air cooler inside the laptop with no open case (Hell will freeze over before I dare to take my tablet apart!). Room temp is about 20C
  15. Tolsk
    Tolsk What's a Dremel?
    14 Jul 2004
    well upgraded my score. but still cant break the 40 second mark.
  16. huren
    huren What's a Dremel?
    14 Aug 2004
    update the board :<
  17. Mister_Tad
    27 Dec 2002
    do you not read threads?
  18. tank_rider
    3 Feb 2005
    Just been doing a bit more fine tuning, got the ol CPU up to 2400MHz running stable and true.
    11 secs improvement on standard, and 500MHz overclock
  19. huren
    14 Aug 2004
    yes i do but i really couldd not be bothered reading through the 20 odd pages after my post.
    but have done now and thanks ~
  20. jaguarking11
    jaguarking11 Peterbilt-strong
    10 Dec 2003
    Sorry ofr the overly large pic but I run dual monitors sort of. The secon monitor is a ps1 lcd displaying samurise.
    Anyways on with my bench
    Yes im using the old version of super pI but thats the one I been using for a while now for my private benching. Tonite I scored the lowes bench in my system ever. The image shows 3cpu-z instances running and tells all about the ram cpu speed and timings.
    But just in case i will type out the specs. p4 3.0C@ 3.6ghz @ 1.66v im runing kingmax pc4000@ 240fsb @ 2.5-3-3-5-8. The mobo is a p4p800 deluxe.
    The mobo I have has a droop mod and im hoping to do a vdim mod witch will hopefully allow me to drop my cas letency. This speed is the maximum 24/7 speed I run my system stably at. I have benched super pi @ 3.75ghz but the time wasent so good because I had way too many things runnning in the background.
    That score was achived with 25processes runing and a 3 month old win xp install.
