Overclocking Results: Super-PI Challenge! (please read the first post)
Discussion in 'Hardware' started by Tim S, 8 Sep 2003.
  1. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Running at 166 FSB might have something to do with it ;)
    The RAM can run 200 at stock - tried that?
  2. Fr4nk
    Fr4nk Tyrannosaurus Alan !
    12 Mar 2005
    I know, I have tried may differant multi's, FSB's & DDR FSB's, Look here It doesn't seem to make a differance T"B"H
  3. Payne280
    Payne280 What's a Dremel?
    19 Oct 2005
    how much do i have to worry about additional heat with the increase of voltage on my RAM, because if I can get that higher than I can probably go somewhere around 2.5GHz
    maybe get my time in the 35s or 34s
  4. Fr4nk
    12 Mar 2005
    your ram should be fine with avoltage upto about ~2.8-2.95 just make sures there's decent airflow :thumb:
  5. Payne280
    19 Oct 2005
    ok sounds good I will up the voltage once i get back to my house where the temps are much colder
    what about increasing the voltage for my CPU?
  6. Fr4nk
    12 Mar 2005
    Well that depends on your CPU cooling, I'd say 1.4~1.5V on stock air cooling, 1.5~1.65(MAX) on good aircooling(like a xp-1200, zalam 7700cu.etc) or watercooling :thumb:
    EDIT: Please look at this thread if you havent already !
  7. Payne280
    19 Oct 2005
    thanks for the link I will be sure to up the core volt some
  8. Eliminos
    Eliminos What's a Dremel?
    2 May 2005
    On my step-brothers Quad-Core 2.5GHz G5:
    26.961s
  9. Payne280
    19 Oct 2005
    upped the memory volt and the core volt and got it around 2.55GHz, best time was 34.656s
    the HTT won't go any farther anyone know what I can do to get it higher?
  10. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    My opteron 146 pulls a 33, but I'm not on it right now so I don;'t have a screenshot.
  11. Fr4nk
    12 Mar 2005
    have you lowered the HTT multiplier? the defualt is x5 so when you run @ 200FSB, its 200*5=1000, then you may up the fsb to ~300 thats 300*5= 1500= :nono: thus you lower the htt multi to x3 the is 300*3=900 :thumb:. in other words keep the HTT total under 1000 :thumb:. that could well be the problem but correct if i'm wrong.
  12. Payne280
    19 Oct 2005
    thx I will try that but I am currently running prime 95 torture test to test an overclock
  13. Mister_Tad
    27 Dec 2002
    nice score, but sadly not comparable as its a different version
  14. TMM
    TMM Modder
    12 Jan 2004
    new score :)
    specs as per sig
  15. Eliminos
    2 May 2005
    Could you find me a correct version that will run on OS/X?
    I got the version I used from here.
  16. TMM
    TMM Modder
    12 Jan 2004
    he means that, because there is not an identical copy of superpi x86 for powerpc's, its impossible to compare as it's code may vary and thus will produce faster/slower results.
    new run:
    That's about tops it will do on this ram, and on air cooling at that (haha gotta slap a delta on my XP-120, only got a low speed panaflo atm). Ram won't go a single mhz more at those timings. I have to set it to 3-4-4 (impacting the speed) to get more out of it, and then it only goes to about 280mhz. dropping to the 183 divider lets me max out the CPU at ~3040mhz @ 1.6v, but then again its still slower because of the slower ram.
    Still happy with it :). Pretty good considering i'm less then 1.5 seconds off pookeyhead who has pretty much the best hardware money will buy atm, watercooled aswell.
  17. Mister_Tad
    27 Dec 2002
    right, I have been thinking to myself over the past few weeks that I should really update the table, take out the old times and put in the times with the new superpi etc etc.
    I just can't seem to find a good chunk of time to do it, how I miss the endless spare time that is university
    This means its delegation time...
    If anyone would like to take over as the official Bit-Tech keeper of all things superpi, drop me a PM :thumb:
  18. Sgoaty
    Sgoaty Minimodder
    4 Feb 2005
    Do ram timings have a big effect on PI? My 146 at 3ghz id doing 30s with 2GB of ram at 3-4-4-8 I see TMM is beating that with his CPU clocked less
  19. Fr4nk
    12 Mar 2005
    Firstly, I'll be working on the new result table tonight, it will be the top 40 in this thread;)
    Secondly TMM has his memory running @ 272Mhz, It's ushually the higher clocked your ram is the better score but timings help abit.
    Finally, heres my latest:
    -34s
    please note Vcore is actually 1.6v NOT 1.8v
  20. Valo
    Valo Minimodder
    11 Aug 2004
    33 second Venice 3000+ run, near-stock volts
