Overclocking Results: Super-PI Challenge! (please read the first post)
Discussion in 'Hardware' started by Tim S, 8 Sep 2003.
  1. Pookeyhead
    30 Jan 2004
    accidental double post
    please delete
  2. Boswell
    Boswell Minimodder
    23 May 2005
    good luck in that i dont think other programs really have a great impact on it.
  3. Pookeyhead
    30 Jan 2004
    They very definitely do. Samurize has a 3% CPU overhead, it makes a difference... around 1.5 seconds actually. Running processes may not.. for instance, Norton, or another background task may have only minimal impact, but something hogging 3% of CPU time definitely does.
  4. Boswell
    Boswell Minimodder
    23 May 2005
    ill wait and see the results then :p
  5. Pookeyhead
    30 Jan 2004
    Fair enough
    Not even trying here... Like I said, I do all my benches at my every day config.. that includes overclocks. Just whacked up the HTT 10 MHz or so... ran Super-Pi... job done. If I really got into RAM timings, vCore adjustments, cooling improvements etc.. 25 or less.. no problem.
    My RAM is limiting me now.. 285 is around max for this stuff. When I get the CE-6 I'll definitely crack 25 secs.
  6. Eliminos
    Eliminos What's a Dremel?
    2 May 2005
    Quite a poor run considering.
    edit: the damn RAM is on a divider, now where is the bios option to turn that off.
  7. Payne280
    Payne280 What's a Dremel?
    19 Oct 2005
    got a new pr of 31.038 with my 165, my previous before that was in the 34s
    I think I could hit sub 30 if I had some better ram and a better power supply because they are the parts in my systm limiting me
    will post pics soon
  8. Eliminos
    2 May 2005
    Thats better. Its so tempting to try and get it to 2.7/2.8
    Its air cooled with 2GB of G.Skill HZ DDR500.
  9. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    Well, I'm running my FX at 2.8 GHz on air; too bad my RAM is holding me back, otherwise I know Id be getting better than 36.8 seconds - especially if I could increase the FSB past 200 MHz.
  10. hitman012
    hitman012 Minimodder
    6 May 2005
    Can't you stick a divider on it? 240 * 12 or 13 with a 166MHz divider will put the RAM at 192MHz. If your board supports a 183Mhz divider, you could put it down to 220 * 13 or 14 for spot-on 200MHz RAM speed. You should still get a better time, even with no gain in memory bandwidth.
  11. homestar
    homestar What's a Dremel?
    21 Feb 2006
    Eh not to shabby
  12. JaredC01
    JaredC01 Hardware Nut
    24 Nov 2002
    Wrong version of SuperPI
  13. homestar
    21 Feb 2006
    Um how? I dl it from this site...first post... so how is it wrong?
  14. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    No it isn't, it's the correct one! Gonna post an updated version for me today!
  15. JaredC01
    24 Nov 2002
    Thought it was supposed to be mod 1.4...
  16. unclean
    unclean SMP obsessive
    30 Dec 2003
    Screenshot
    27.578 - Opteron 144 @ 3,065MHz, 2 x 512mb Ballistix PC4000 @ 283MHz, all air
  17. hitman012
    6 May 2005
    Be sure to get all these good times into the hwbot thread. It'll automatically rank you rather than waiting for someone to update a table :)
  18. tank_rider
    tank_rider What's a Dremel?
    3 Feb 2005
    unclean what cooling have you got on that badboy? I'm tempted by a high flow fan to see if i can crack 3GHz with mine as i'm only running an akasa amber on my XP-120
  19. unclean
    30 Dec 2003
    tank_rider, usually on a TDX/BIX 120mm/ 1/2" R3603 WC loop.
    Was swapping CPUs about, so was using a Zalman 7700CU (super flower) on it for that benchie :)
    (Was setting up a little LAN at the time in a garage and the heating hadn't really got into action so I'd say idle was about 10 degrees C.)
  20. samboush
    samboush What's a Dremel?
    23 Feb 2006
    OPTERON 144 socket 939 @ 2.7GHZ
    MicroStar K8N Neo2 Platinum-54G - nForce3 250 vs. Opteron 144 sock939
    RAM KHX 533 MHZ 2*512
    Opteron 144 sock939 1.8@2.7G 1.5V
