Overclocking Results: Super-PI Challenge! (please read the first post)
Discussion in 'Hardware' started by Tim S, 8 Sep 2003.
  1. JaredC01
    JaredC01 Hardware Nut
    24 Nov 2002
    You say you're running 533MHz RAM, yet in the tests, you're only running it at 193MHz... Something I missed here? :worried:
  2. DAE_JA_VOO
    DAE_JA_VOO What's a Dremel?
    11 Nov 2005
    Okay, here's my system spec:
    CPU: AMD X2 4400+ @ 2.77 (252x11)
    RAM: 2GB (2x 1GB) Mushkin Redlines XP4000 (3-3-2-8) (still need to tweak this, only got it a few days ago)
    Video: 2x XFX 7800GT
    And here's my SuperPI result:
    Ther's obviously something wrong with CPU-Z as it says my VCore is 1.35, which it isn't, it's at 1.5. CPU-Z also says that my RAM is running at 163Mhz, which would be impossible because i'm using a 1:1 divider. Hmmm...
    But, my score is 33.156, my best so farb has been 33.072 though...
  3. samboush
    samboush What's a Dremel?
    23 Feb 2006
    No , but u got a point. With winchester3000+(My) its posible to run 9x270 fsb with 200/200 ram Freq div 540 DDR 200/200 3.4.4.8 1T. But not with Opteron 144(My TCMax 57) I can put here Pi result , with Opteron144(My TCMax 57) 9x312 2.808 Ghz with 1.54v 133/200 ram Freq div 401 DDR 2.5 3 3 6 1T it's under 30s. But it crashed sometime. 9x300 fsb 2.7GHZ 1.5v 133/200 ram Freq div 386 DDR 2.7 V 2.5 3.3.6 1T it's absolutly stable in any situation for me. I tryed many situation with My opteron like 166/200 ram Freq div and i end at 260 FSB . I think that opteron doesn't like RAM runing more then 400 DDR generaly. If u can give to me any good advice. I will be very pleased.
    Thanks S.
  4. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Had similar issues with the 144 here, ended up having to run the ram at 1:1 as it didnt want to run dividers.
    Playing with the ram alpha timings helped out stability wise, this might be an option for you as well :)
  5. Mary Jo
    Mary Jo oh lolz
    13 Oct 2004
    31.160s on a 3700+ SD @ 270x10. 2GB Crucial Ballistix PC4000, DFI SLI-DR.
    You can see most of the timings etc. on the screenshot.
  6. Cruelinios
    Cruelinios EvE Addict
    21 Jan 2002
    New run on my watercooling
  7. ArsoN
    ArsoN What's a Dremel?
    30 Sep 2003
    Clickor.
    What else to say? Cooled by an XP120a. Wouldn't quite do 2.5 stable, that could be down to my low powered PSU though (it's barely running this machine now with SLI), I'll try my luck again once I've got a new one.
  8. Linkz42
    Linkz42 What's a Dremel?
    9 Apr 2006
    amd anthlon 4400+ x2 @ 2.62ghz vcore 1.45
    x2 ocz plat rev 2. ddr400 @ 262mhz voltage 2.85 1T(2.5-3-3-7)
    asus a8n 32-sli
    cooling: Air
  9. simon_C
    simon_C Minimodder
    13 Nov 2005
    sorry for the badly compressed image
    AMD Athlon 64 3000+ Venice socket 939
    Stock: 1813mhz
    OverClocked to: 2506mhz
    Multi: 9x
    HTT: 278.5
    V: 1.584v
    Stepping: 2
    Asus A8N-E motherboard
    OCZ premier series DDR400 memory, 2x 512mb sticks. dual channel.
    Overclocked to: 228mhz
    CAS: 2.5
    Zalman 7000cu-led copper heatsink. running at 32*C under heavy load.
    :D did i do good?
  10. TMM
    TMM Modder
    12 Jan 2004
    not bad, though 2.5G @ 1.6v is pretty much, dare i say it, a lemon. The time is good for 2.5 though :)
  11. simon_C
    simon_C Minimodder
    13 Nov 2005
    just a step along the path my friend. im still going up!
    see:
    Stock: 1813mhz
    OverClocked to: 2661mhz
    Multi: 9x
    HTT: 295.7
    V: 1.584v
    Stepping: 2
    CAS: 2.5
    Zalman 7000cu-led copper heatsink. running at 36*C under heavy load.
  12. meko360
    meko360 What's a Dremel?
    17 Apr 2006
    I would like to share the results of my new Venice 3000+ :rock:
    TIME: 1m00.485s
    CPU: AMD Venice 3000+ 1800mhz @ 3262.7mhz
    COOLING: Dry Ice
    MOTHERBOARD: DFI Lanparty Ultra-D
    MEMORY: 2x512 Corsair XMS PC3200
    PSU: OCZ Modstream 520W
    :thumb:
  13. hitman012
    hitman012 Minimodder
    6 May 2005
    Nice clock/score ;)
    May I direct you to the hwbot thread where you can post your 1M score and have it automatically ranked...
  14. meko360
    17 Apr 2006
    Many thanks capt'n!!
  15. simon_C
    simon_C Minimodder
    13 Nov 2005
    holy jesus..... 3262mhz? how the hell did you manage that?
  16. meko360
    17 Apr 2006
    I cooled the CPU with dry ice.
  17. simon_C
    simon_C Minimodder
    13 Nov 2005
    ah.... last i looked it said air cooling.....
  18. meko360
    17 Apr 2006
    Yes, was my mistake. I've got a lot of screen captures with d-ice, with air... I get confused. :p
    As far as I can see that version of Cpu-z does not recognize memory latencies very well, CPU settings are OK.
    I'll mount the d-ice kit again in few weeks to see what else this can do.
  19. FIBRE+
    FIBRE+ Minimodder
    27 Feb 2005
    30.255s :)
    Had a little session, no fancy fiddling, just air...
    A64 X2 3800 @ 2841GHz (1.5v) - 1gig OCZ Platinum PC4200 @ 284MHz 2.5-3-3-6 1T (2.85v)
  20. treys1
    treys1 What's a Dremel?
    2 Jun 2006
    30s
    Im new to this forum but have been playing with this machine for a while.
    http://home.treys1.com/pics/pi.jpg
    Pentium D 950 @ 4259 MHZ
    See my signature for more details!
    Oh Yeah, how do I put my picture in the post?
