Overclocking trouble
Discussion in 'Hardware' started by alpha112, 3 Jun 2005.
  1. alpha112
    alpha112 Minimodder
    23 Aug 2004
    Im just getting in to overclocking and Im having some problems.
    Ive just bought some BH5 memory and put it in my PC, but it isnt working too well:
    It gets errors on prime95 after ~5mins running 200mhz@2.6v, and with the FSB any higher, even if I push the voltage up (the board tops out at 3.2v).
    Ive tried upping the core volts on the cpu but it wont go above 225*17 without windows blue screening before it gets to the desktop. I think maybe this is the ceiling of the chip.
    Temps are good after rejigging my fans ~45degrees at stock.
    Any help would be appreciated, thanks.
