Overlclocking on a budget ?
Discussion in 'Hardware' started by Hippo, 22 Feb 2004.
  1. Hippo
    Hippo Pre-dates 5.25" Floppies
    7 Mar 2003
    My Current Mobo/CPU/Ram is starting to look a little ragged now (My mobo doesnt even support DDR ram :sigh: ) So im going to upgrade. However im on a little bit of a budget. Also i want to have a tinker with overclocking.
    I've half decided on the following hardware, does anyone agree or have any other ideas for me ?
    AMD Duron 1800 266FSB CPU - OEM £22.99
    Asus A7V8X-X SKT A KT400 8x AGP DDR Sound/lAN/USB 2.0 £35.87
    Crucial 512 DDR333 PC2700 DIMM £44.99
  2. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    They sound ok for a budget. COuld you give us a number to work with so as to suggest alternative specs? You will need a heatsink to go with those.
  3. Hippo
    7 Mar 2003
    Ive got my Thermaltake Volcano 11 for cooling :)
    My pricerange is around £125-ish although i wouldnt mind paying a little more but not much :eeek:
  4. Xen0phobiak
    8 Aug 2002
    Hippo likes this.
  5. Hallq16
    Hallq16 What's a Dremel?
    30 Aug 2003
    What do you need, are Nforce2 Ultra 400 motherboard, AMD cpu with TB Core, and atleast pc3200 RAM.
    Example:
    AMD AthlonXP 1800+ (1533MHz) 256KB L2 cache 266MHz Bus T-bred (maybe you can o/c it to 2800+ or so, if you get cpu with right stepping... cant remember which ones are good though)
    Epox Socket A EP-8RDA+ nForce Ultra 400, ATX (cheaper than Abit/Asus)
    TwinMOS DDRAM PC-3200 400MHz 256MB CL 2,5 Review (later you can add another 256mb RAM, and then you can benefit from Dual-DDRAM.
