Modding Overpowering a neon?
Discussion in 'Modding' started by Hindaine, 14 Nov 2002.
  1. Hindaine
    Hindaine What's a Dremel?
    23 Oct 2001
    (not sure if this belongs in hardware or modding)
    So, i have this little 5 inch neon, designed to take 12v (obviously).
    The source i wanna use is 14v. I need to know if it would be okay to just plug and go, or if i should get a resister and which one.
  2. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    Most likely it will be just fine,
    Car products are made to run off 13.5 volts so 14 volts should be no problem.
    I powered the neon string for my halloween light sabler off 18 volts with zero problems.
  3. Hindaine
    23 Oct 2001
    Thanks zap
