Case Mod - In Progress P|NNED - K|NGP|N´s Empire
Discussion in 'Project Logs' started by CustomRigs, 18 Aug 2019.
  1. CustomRigs
    CustomRigs CallMeCleaner
    8 Dec 2017
    Project "P|NNED" K|NGP|N´s Empire !
    This is a new project where i manufacture my first casecon ! Thanks Rainerthat you trust in me again [​IMG];) I build this beast for him.
    First thing ... the projectname is "P|NNED" ... as you can read from the letters it has someting to do with K|NGP|N.
    It is a openframe case and you can use it like a benchtable
    That casing can hold four 480mm radiators ! You may ask yourself "why you need four 480mm rads ?"
    Some Hardwarespecs for you [​IMG];)
    Hardware
    CPU: INTEL I9 9980XE 18cores 36threads
    MB: EVGA X299 Dark
    GPU: EVGA RTX 2080 Ti K|NGP|N with the Hydrocopper waterblock
    RAM: 64GB HyperX Predator QuadKit 3200MHz CL16 (noRGB)
    SSD: TBA
    HDD: TBA
    PSU: Seasonic Prime 1300 Platinum
    Cables: Cablemod full sleeved set
    Watercoolingparts
    CPU Block: Watercool Heatkiller IV
    GPU Block: EVGA Hydrocopper
    Radiators: 2x 480mm Hwlabs Nemesis GTS and 2x 480mm Nemesis Hwlabs GTX
    Res: 2x Heatkiller Tube 150 D5
    Pump: 2x Aquacomputer D5 Next parallelmode
    Tube: Mix from HT and EK ZMT with some quickies
    The design of this casecon should mind to the EVGA gpu cooler design from the K|NGP|N and FTW3 models.
    All parts are made from aluminium sheet in 2 and 3mm and getting powder coated in matt black.
  2. CustomRigs
    8 Dec 2017
    some of the hardware arrived :)
  3. CustomRigs
    8 Dec 2017
    some more pics :)
  4. CustomRigs
    8 Dec 2017
  5. CustomRigs
    8 Dec 2017
  6. Yury
    Yury What's a Dremel?
    7 Mar 2019
    Beautiful hardware, following
  7. CustomRigs
    8 Dec 2017
    i leave this here ;) now i have to do some work on the mesh and hardware and watercooling parts.
    Also the screws getting exchanged tomorrow with nice black ones :)
  8. CustomRigs
    8 Dec 2017
    P|NNED Update ... Radiators and fans are mounted :) also you can see my own designed cpu cooler top with a Heatkiller bottomplate inside. On the backside the four 480mm radiators and the nice Prime 1300W Platinum PSU are mounted :)
    The silver screws getting exchenage against nice black lens head screws ;)
    Also the mesh looking really good ! The K|NGP|N 2080 Ti Hydrocopper gets mounted vertical. I have to drill some holes for the vertical holder tomorrow. After that i can measure the length of the cables.
    Cheapskate likes this.
  9. CustomRigs
    8 Dec 2017
    update :)
    GPU its on its place ! First tubes are in
  10. CustomRigs
    8 Dec 2017
    today i put the cables in and mounted the hdd and ssd´s :) .. time to fill the loop :D
  11. pcroombrasil
    pcroombrasil Minimodder
    27 Nov 2017
    very nice this case.
    CustomRigs likes this.
  12. CustomRigs
    8 Dec 2017
    Im done :) it runs great ! performance video is coming soon !
    Vandalo and neSSa like this.
