P180 vs P182?
Discussion in 'Hardware' started by BioSniper, 19 Apr 2008.
  1. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    I'm looking at finally changing my Chieftec Dragon that I've had for an age now to something a little.. quieter and more modern.
    The P182 naturally takes my interest however the local shop needs to order them in or I will have to order online.
    Now, I've read after a fair bit of browsing that the newer revision P180 is the same minus the 270 degree door and has a silver finish instead.
    So, do you think I'd be better off ordering the P182 from the internets or buying the P180 in the shop? Both are £82 and £85 (180/182) respectively and I'm fairly happy to live without the 270 degree door.
    What's your thoughts?
  2. atanum141
    22 Jul 2004
    Just go for the newer one. i think the door is a smart idea and maybe needed one day.
  3. wyx087
    15 Aug 2007
    i thought the p180/182 are all the same.
    earlier p180 don't have the cable management, now it does. so as far as i can tell, they are both the same.
    but why not go for p182 if it's only a few quid. and don't forget it's got a better finish (not silver, it's gun metal black)
    keep in mine both p180/2 are very heavy.
  4. shadow12
    shadow12 I lie
    30 Sep 2007
    I have a P182 and I love it.
  5. willowthewhite
    willowthewhite Minimodder
    7 Nov 2006
    I have to agree with this, fantastic case, can't fault it.
  6. Jipa
    5 Feb 2004
    I currently have the whole lot: P180B, P182 and P180 Mini. My P180 is supposed to be a rather early model, but even it has the 270 degree door. What it lacks instead is the cable management, and that's a huge loss. The finish on the P182 is nice dark grey, but I still prefer P180B over it.
    If the P180 you're looking at is new then the only difference should indeed be the color. IMO Antec should have renamed the P180 and P180B into P182S(ilver) and P182B when they did the modifications....
  7. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    Thats the upgrade i made last month, hugely worth it mate. Get the 182 from scan its bout £90.
  8. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Both are nice cases but I'd get a P182
  9. kno3
    kno3 What's a Dremel?
    29 Mar 2008
    Yeh, same, i have it, and i love it! There are some differences between the 180 and the 182, the 182 has some nice water cooling features, like grommets for getting tubes in/out of your case. Get the P182, it is slightly better.
  10. graysky
    graysky What's a Dremel?
    25 Mar 2008
    +1 for p182. I love mine.
  11. BioSniper
    5 Feb 2002
    I may have to hold fire on it anyway now as I don't really have enough money this month but cheers for the opinions :)
  12. wyx087
    15 Aug 2007
    Novatech have p182's. you live in Portsmouth right? you can just go and collect there.
  13. MontanaFX
    MontanaFX Sent from the skies
    23 Apr 2008
    It has to be the P182 although the newer P180 are very similar. If you really like the colour of the P180, go for that. The performance levels are quite similar with the two models.
  14. Fishlock
    Fishlock .o0o.
    22 Nov 2004
    P182SE is the winner ;)
