P3 Micro ATX MB's?
Discussion in 'Hardware' started by Angel_of_Death, 17 Sep 2002.
  1. Angel_of_Death
    Angel_of_Death What's a Dremel?
    9 Apr 2002
    I'm planning on putting my old P3 1ghz system into a Lian Li PC9300 case to build a home entertainment system thingy. But i'm faced with the problem of finding a Micro ATX P3 board with an AGP slot and at least one PCI slot.
    Got any idea's? :eyebrow:
    AoD :rock:
  2. Riffer
    Riffer What's a Dremel?
    6 Sep 2002
    Look at some of the boards from Aopen and Gigabyte.
  3. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    Asus do some small motherboards
  4. cderalow
    cderalow bondage master!
    23 Jan 2002
    shuttle as well
    the thing is if it's a slot pIII you'll have a lot more trouble....
    but if its a socket 370/fcpga it won't be as bad...
  5. Angel_of_Death
    9 Apr 2002
    Thanks for the help. :D
    I've gone and taken a look at some of the Asus boards, they look quite promising so what i need to know now is where can i get them in the UK?
    Btw its a socket 370 not a slot. Can you actually get a slot version?
    But as i said above, thanks for the help :lol:
    AoD :rock:
  6. Jamie
    12 Mar 2001
    Slot 1 if my memory serves me right.
  7. Guest-16
    Guest-16 Guest
