Motherboards Packard Bells technical *support*
Discussion in 'Hardware' started by mrbungle, 19 Aug 2013.
  1. mrbungle
    20 Sep 2004
    I resurrected a old imedia computer running a Q6600 and wanted to upgrade the bios so I could stick a later generation core quad in it as I want the Q6600 for another machine.
    The website is as awful as I remember it being when I used to do tech work a few years ago, they seem to dump anything off the site that isnt current which makes finding drivers and updates a bit of a challenge.
    Here is the response to my request of a link for a late bios:
    So not only do I need a expert I also need a local technician to help me in my quest for the lost bios updates :sigh:
    I think I will leave it as it is unless anyone can track down a bios for a pts73 motherboard!?
  2. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    Have you tried running HWInfo to see what the motherboard really is?
    A search for PTS73 brings up mention of Asus - it might have an Asus mobo inside, so you could be in luck. As far as I know, Packard Bell always used third party motherboards, so you should be able to find a BIOS with some digging.
  3. mrbungle
    20 Sep 2004
    On first inspection it looks like a bog std matx board until you realize it only has 3 pci slots not the standard 4... so I think its unlikely I will be able to flash it with a off the shelf bios for a Asus board.
    It isn't a big deal, the lack of support makes me think there might not be any updates for it anyway it was just the awful response made me laugh.
  4. saspro
    saspro IT monkey
    23 Apr 2009
    Most matx only have 3 PCI slots (or pci-e on new ones) + 1x PCI-e or AGP
  5. murraynt
    murraynt Modder
    6 Jun 2009
    If it is an ASUS board maybe Bindi could help?
  6. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    PB normally use modified Asus or Gigabyte boards. You might find a similar model with a slightly different name or features that the PB board doesn't but the BIOSes are normally incompatible.
    I've found a modified P04 BIOS here that might be newer than the one you currently have. Searching for "Packard Bell Stingray" might come up with more info.
    Edit: P07 (2008-09-24) can be found here but it'll require an account to download. I've tried the Wayback Archive of the PB site (it used to be rather informative before Acer took them over) but no luck.
    mrbungle likes this.
  7. law99
    law99 Custom User Title
    24 Sep 2009
    Acer took over Packard Bell... those are two names you don't want to hear in quick succession.
  8. mrbungle
    20 Sep 2004
    I meant 3 total, hence a matx will not fit in the diddy case
    I will investigate those links, +rep!
