Hey guys. I need some help. I have an arylic tube that i want to use in an mode the trouble is its clear and i need it to be green. What type of paint should i use and if i was to stick a green ccl in side the tube would i get a nice green glow.
you don't even need to paint it. All you need to do is grab some green translucent wrapping paper and grab clear scotch tape and your done
well in that case, I recemmend kylon fusion if you really,really,really,really,really want to paint it. You're able to find it in dickblick.com. It's an online art store.
And make sure you mask off EVERY area of the plastic you don't want paint on because the mild surface charge of static on the plastic can suck paint right out of the air.
