Modding Paint Question
Discussion in 'Modding' started by El Nosba, 23 Sep 2003.
  1. El Nosba
    El Nosba What's a Dremel?
    22 Sep 2003
    First off i just wanna say hi to everyone on these boards, as ive been lurking them for quite awhile and i finally joined cause im starting a full mod project ( nothing is being divulged at the moment, but i will post a work log once i start on it hehe :D ) and have a question.
    Say i wanted a paint job on aluminum to make it look like wood ( professional job, not something im gonna do myself ) how much increase in the thickness am i looking at ?
    Its not about clearance issues :rolleyes: , its just for future refference for myself :cooldude:
  2. tmerelin
    tmerelin What's a Dremel?
    23 Sep 2003
    N00bie replying to another n00bie! Increasing the post-count..
    The paint thickness is heavily dependent from the paint you're using. But supposing you're painting wood patterns this is going to be multiple layers. It's really hard to estimate, but a single layer of sprayed paint is about .1 mm thick. Hand painted varies between .3mm to 1mm.
    Why don't you try a tape (is it tape or a film or ...) that has wood grain printed on it! Same You would use on covering shelves or making a tacky caravan interior.... Waaay cheaper and you can measure the exact thickness! :rock:
  3. El Nosba
    22 Sep 2003
    fantastic idea :thumb:
    but alas... im going for a very specific pattern, and im gonna need to get it painted :wallbash: :waah: :waah:
  4. TheoGeo
    TheoGeo What are these goddamn animals?!
    10 Jun 2003
    welcome to bit-tech, i aint been here long myself. you shouldnt be adding too much thickness to it, it depends how its being done. shouldnt be more than a couple of mm if its paint
