Modding Painting a case help
Discussion in 'Modding' started by zhangmaster12, 1 May 2007.
  1. zhangmaster12
    zhangmaster12 What's a Dremel?
    11 Jun 2006
    Hi all, my antec p180B is a bit scratched up, and i want to fix it. i was thinking about how to paint the side panels so that it looks like the origonal brushed alu style
    Also, i need to paint the top, its also scratched. its plastic, is it possible to paint it a matte black? If so, how?
    Thanks all.
  2. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
  3. bumfluff
    bumfluff What's a Dremel?
    18 Aug 2006
    There was a tutorial over on coolercases.co.uk in the forums where the guy painted his mouse, that is made of plastic.
  4. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    You just need a primer that will adhere to plastic then pain on top of that. also sand the surface with 240grit to make a better surface.
  5. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    On the side pannels, anyway, getting the black-anodized-brushed-aluminum look back will be rather tough with paint. If the scratches themselves aren't too bad, a black sharpie will get rid of the silver color and leave the grain visible.
  6. zhangmaster12
    11 Jun 2006
    the scratches arent bad only a few, but i want to make them invisible. With a shrapie they are still faintly visible.
    thanks for teh replys
  7. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Krylon's Fusion Paints are made for painting plastic. You need to prep the plastic surface by cleaning it first with a degreaser spray like "Simple Green" or "409"
    If you wish to use an automotive touch-up spray instead, you must use Flexible Primer for your base coat first on plastics.
    (btw: "Self Etching" Primers are for Metal Surfaces)
  8. zhangmaster12
    11 Jun 2006
    ty everybody
