Modding Painting a keyboard
Discussion in 'Modding' started by Kronos, 12 May 2015.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    I am going to be getting a mech keyboard shortly and as really hate the black casing it will be out with the spray cans again.
    This time I thought I might use Plasti Dip so anyone had experience of this stuff? Is it the same as or similar to PlastiKote as I quite like the finish that gives.
    And any tips on the whole process? It won't be the first cast I have done but still have a lot to learn.
  2. David
    7 Apr 2009
    Vinyl dye.
  3. Kronos
    Kronos Multimodder
    6 Nov 2009
    Common Dave you can do better than just two words.lol I have heard about vinyl dye but will it work on black if I want to go white for instance.?
    How does it compare with Plasti Dip or Plasti Kote?
    Found this though. http://forums.bit-tech.net/showthread.php?t=174054
