Modding Painting Aluminium
Discussion in 'Modding' started by dipzy, 20 Jan 2015.
  1. dipzy
    dipzy Minimodder
    5 Jan 2013
    Hi guys,
    not sure if this is the right section to post or if I've already posted this before.
    I want to paint the aluminium light bar that you get on corsair Dominator Platinum white.
    I've never done this sort of thing before. Is there a place in the UK or a member on here that does this?
    Thanks,
    Dipak
  2. Nexxo
    23 Oct 2001
    Use some car body primer spray (matt grey) as a base coat and then a nice white car body paint spray as a top coat.
  3. Arboreal
    21 Jan 2011
    Excuse the intrusion dipzy...
    I've been meaning to ask for ages, does it need to be proper aluminium etch primer?
  4. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    scratch it > clean it > etch prime it > Prime it > colour it > protect if need
  5. dipzy
    dipzy Minimodder
    5 Jan 2013
    Thanks guys, i will try on test pieces very soon :)
  6. Impatience
    Impatience Minimodder
    6 Apr 2014
    Quick question on this topic.. Is it possible to get two in one primer/spray? I have ordered some spray that says it primes itself, but not too sure as it was on the cheaper side of the price range.. Do you lot think I should I prime it anyways just in case?
  7. IamJudd
    IamJudd Modder
    30 Oct 2011
    It is... I bought separates though as it allowed more colour choice after the primer. Then again, I did purchase from a smaller B&Q...
