Modding Painting an inverter...
Discussion in 'Modding' started by NOMIS, 8 Jul 2005.
  1. NOMIS
    NOMIS What's a Dremel?
    7 Jun 2004
    Has anyone painted an inverter for a cathode before, and can share some tips? I know these things can cause some problems, I don't really wanna screw anything up.
    I suppose Vinyl Dye would be better to use yes? Is it worth painting/dying it, are there any risk?
    Cheers
  2. jerb111
    jerb111 What's a Dremel?
    25 Oct 2004
    just pop it apart and vinly dye the outer caseing, there should be no problems at all :hip:
  3. GigantoR
    GigantoR What's a Dremel?
    21 Jul 2004
    As long as you take the plastic shell off of the inverter and then paint that seperately from the actual pcb inside, you should be fine.
  4. NOMIS
    7 Jun 2004
    Sweet, thanks for your help fellas.
  5. Ghlargh
    Ghlargh What's a Dremel?
    16 Nov 2003
    I would say that as long as you don't dip it in paint or use conductive paint, you can very well paint it without taking it apart.
